Are Voltage Testers Safe? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-06-2009, 01:23 PM   #1
Rewards Points: 384
Are voltage testers safe?
I would assume so but I feel weird touching a little tool to a live electrical line. Most of the time it's off and I'm using to verify that but the times it's on a different circuit then I thought(thank god for the tool) I touch a live line. I'm assuming since the tool is all plastic it's fine but would I be fine using this in the panel to check the power too? Is there a max these tools can safely handle?
The one I'm using is:
http://www.amazon.com/Fluke-1AC-A1-I...6900844&sr=8-1
RyanD is offline   Reply With Quote
Old 07-06-2009, 01:26 PM   #2
Code05's Avatar
Rewards Points: 1,104
If it says CAT III your are good.
Code05 is offline   Reply With Quote
Old 07-06-2009, 01:35 PM   #3
Journeyman Wireman
i have done 480 with them. you should be good with anything around your house. they will lie to you sometimes
jbberns is offline   Reply With Quote
Old 07-06-2009, 01:42 PM   #4
300zx's Avatar
Post
They can give you false readings. Best tester for the money would be a wiggy Solenoid type tester. Non-Contact Voltage Testers have shocked me more than once.http://www.grainger.com/1/1/63069-wi...-iii-600v.html
300zx is offline   Reply With Quote
Old 07-06-2009, 02:46 PM   #5
Plus the Wiggy doesn't respond to phantom voltages. Troubleshooting is hard enough without chasing ghosts.
Old 07-06-2009, 02:48 PM   #6
Rewards Points: 384
...But it gives false positives and not false negatives right?! I can live with false positives...not so much with false negatives.
Old 07-06-2009, 04:09 PM   #7
No false negatives for liability reasons and you'll get tired of false positives soon enough.
An incand. bulb across the leads of a voltmeter is pretty good but it will trip an upstream GFCI if you measure between hot and ground. So might a Wiggy.
Old 07-06-2009, 04:15 PM   #8
Rewards Points: 2,350
duplicate
Old 07-06-2009, 04:16 PM   #9
Depends on the state of the battery, and the condition the contacts to the battery are in. Sometimes, especially on the Greenlee tester, you will turn the thing on, but it isn't really on, because of corrosion on the battery, and it won't read. For this reason, you either test it on a known hot, or rub it on your shirt or hair, because the static will cause it to chirp if it is working.
Old 07-06-2009, 04:34 PM   #10
300zx's Avatar
Post
I like Learning The Hard Way(First and Last time i trusted a Non-Contact Voltage Tester )
Old 07-06-2009, 04:42 PM   #11
Wasn't that spectacular?
I guess they don't care about liability. . .
Old 07-06-2009, 04:49 PM   #12
300zx's Avatar
Post
Yes and loud!! And still didn't trip the Breaker (Federal Pacific)
Old 07-06-2009, 04:58 PM   #13
If you think about, that was one of the easier ways to learn. It only cost you a $35 pair of cutters. Could have been worse.
Old 07-06-2009, 06:33 PM   #14
Bigplanz's Avatar
Rewards Points: 914
I melted off the tip of a pair of needle nose pliers once. BANG! sounded like a 22 being shot off next to my ear. Yeah, I learned to double and triple check.
Bigplanz is offline   Reply With Quote
Old 07-06-2009, 07:53 PM   #15
Better yet, it almost looks like it turned the cutters into a serviceable wire stripper, even Steven.
everyman is offline   Reply With Quote
high voltage fire alarm jungboklee Electrical 3 01-26-2009 10:07 PM
Low voltage box question WShawn Electrical 7 08-19-2008 07:22 AM
2 - 900w tansformers on a 15A circuit? tonyBagadonuts Electrical 19 07-20-2008 08:15 PM
Low voltage to vacuum l.schrankel@comcast.net Electrical 2 03-04-2007 10:38 AM
Gun Safe vs. Floor Joists allen1466 Building & Construction 9 03-03-2006 09:16 AM
