Voltage Tester - Electrical - DIY Chatroom Home Improvement Forum
Old 07-02-2012, 05:36 PM   #1
Rewards Points: 16
Voltage tester
I found a Dayton voltage tester that has a function to check for "R/C Leakage" Meter goes from 115v to 550v. Have no idea on what this is.. Thanks
Jed54 is offline   Reply With Quote
Old 07-02-2012, 05:38 PM   #2
Rewards Points: 776
and your question is?
curiousB is offline   Reply With Quote
Old 07-02-2012, 06:13 PM   #3
Rewards Points: 16
OK......... what is r/c leakage?
Old 07-02-2012, 06:31 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 142
Pics or model #?
Old 07-03-2012, 03:57 AM   #5
Oso954's Avatar
Rewards Points: 438
An r/c circuit is a resistor/capacitor circuit. The leakage is the voltage leakage of the circuit (primarily from the capacitors).
Depending on the age of this tester, it maybe an old tube era capacitor analyzer. They were real important for fixing radios, TV's, phonographs, etc.
There is a company called Dayton Audio that may be the maker of your instrument.
Oso954 is offline   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
PaliBob (07-03-2012)
Old 07-03-2012, 05:59 AM   #6
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Jed, Caution on that R/C Leakage test. Some old time tester generated very High Voltages to measure leakage.
Please include a pic and/or model info. Some of these old testers are highly valued by collectors.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 10-30-2012, 02:04 AM   #7
R/C leakage
Try using the latest tester. I'm sure you are using the old one that's why you get this 115V-550V.
_____
small volume pcb assembly
denton82 is offline   Reply With Quote
Need recommendation of non-contact voltage tester miamicuse Electrical 6 05-22-2012 05:33 PM
Resistor/Led and Basic Electricity Questions Khivar Electrical 19 04-16-2012 07:15 PM
Voltage Detector Affected by Snow? Arnold Ziffel Electrical 1 02-01-2012 10:56 PM
Need advice on whats the best non contact voltage tester humberguy Electrical 16 12-31-2011 03:37 AM
Odd behavior of voltage tester across switch terminals? darsunt Electrical 12 08-20-2009 09:28 PM
