Voltage Sag Or VD. Where Do They Draw The Line In The Sand? - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 05-11-2011, 03:52 PM   #31
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Anyway, I did want to ask you guys about transformer ratings. I understand KVA and KW, and the relation within but curious where the engineered margins are in transformers
I hope you don't perform work for your customers with the same "anything to save a buck" attitude. You need to quit playing around with that federal pacific panel with the problems and the dryer range combo circuit with the illegally sized wire and and any other problems you have and put in the correct size commercial service.
I would love to be around when the POCO realizes you are running a commercial business on a residential service with residential rates and all. They don't like that 'cuz it costs them a lot of money.
It is just ridiculous to consider operating a: I have a 12000sf building to climate control and all the equipment on a 100 amp service along with the house.
Old 05-11-2011, 04:00 PM   #32
Rewards Points: 242
I think you got your facts a little off, based on my posts. Range has been corrected, Breaker Panel will be upgraded to a GE 200A with 4/0 Al, and no, I am not trying to run my 12K sf shop with this.
The PC here anyway DOES charge a premium for residential service and told me straight up that if I need it, they will deliver it. They just want to sell juice. The price around here is .06/kw for 3ph and .12/kw for 1ph.
You need to realize I DID NOT BUILD THIS HOUSE!! It was poorly built with some questionable electrics in some areas but yes, I am try to save money where I can. Shame on me for trying to save money.
viper is offline   Reply With Quote
Old 05-11-2011, 04:47 PM   #33
nap
You talking to me?
nap's Avatar
kW for a commercial service? Um, ok, if you say so. You apparently do not understand what I was even talking about.
then why would these big CNC machines be drawing on this service you are dealing with? You can't change the story and expect to be believed. You are the one that said you could run up a machine and draw 300 amps on this service.
and it's not shame on you for trying to save money but with at least 6 POCO's that I deal with, what you are doing is outright illegal.
Old 05-11-2011, 05:03 PM   #34
Rewards Points: 242
Well, with having only 50% of the story and not realizing I have 3 properties, I can see where you would be confused and yes, one of my shops is a 12k sf facility with a 600A/240V delta 3ph service. I have some stuff at home.
Never the less, this thread seems to be turning into a pissing contest so I will bug out.
Old 05-11-2011, 05:30 PM   #35
nap
You talking to me?
nap's Avatar
delta on a service to a new building? ? and 240 V? um, ok, if you say so
would that be a floating delta, corner grounded delta, or center tapped delta?
Old 05-11-2011, 05:46 PM   #36
Rewards Points: 242
Just more points for shooting from the clouds.
Fact is, this is a world wide forum and you DO NOT need to know my life story, nor does the whole world. I asked a simple question. I got what I needed. I am sorry that I do not wish to fill you in on every detail so you can pick it apart.
Do you do this to everyone or do I attract your type for some reason?
Old 05-11-2011, 06:03 PM   #37
nap
You talking to me?
nap's Avatar
people I believe may be committing crimes do tend to attract me.
as to me picking anything apart; that is simply to judge veracity and so far, you have failed.
as to knowing your life and it being a world wide forum: you do realize that there is no more anonymity on the internet than the means a person is limited to in tracing you. You would be amazed at how known you already are to those with the means to discover it.
Old 05-11-2011, 06:20 PM   #38
Rewards Points: 242
I dunno what to say but you win...Champio n stuff.
Where is the icon for ego stroking? I cannot find it...
I have no idea what crime I am committing or inaccuracy in my posts but I feel better that the "forum police" is here.
Old 05-11-2011, 06:46 PM   #39
nap
You talking to me?
nap's Avatar
to the ego stroking emoticon: works pretty good. Feel free to use as many as the forum will allow.
Old 05-11-2011, 06:50 PM   #40
Rewards Points: 242
:c lap:
Old 05-11-2011, 06:57 PM   #41
nap
You talking to me?
nap's Avatar
where's the kowtows?
Old 05-18-2011, 12:48 PM   #42
Rewards Points: 242
Meter monitor data was downloaded by POCO and determined that I had sufficient loads along with problematic line loss from a long cable pull from transformer to justify installing me my own transformer. OUTSTANDING! Should be done in a few days.
Old 05-18-2011, 02:39 PM   #43
Rewards Points: 1,548
Commercial power accounts may or may not include a "demand" charge. This is a surcharge if you draw more than X amperes at any time during the month. Different ways exist for computing the surcharge, for example it may be bigger if you make the large draw during certain designated peak hours, or it may be bigger if you make the large draw more than once, etc.
Old 05-18-2011, 02:56 PM   #44
Rewards Points: 242
As I understand it from our POCO, we will likely be getting demand meters for all residentials soon BUT will not be charged for it as a residential (so they say). It will soley be used to improve power distribution and grid monitoring. He said there was not going to be any KVARs systems or anything like that that would be typical in a commercial service around here.
In any case, my peak inrush currents rarely exceed 150A and continuous would be pushing things at 100A but only for shorter amounts of time. Just have to figure a welder, 10HP air compressor along with the wife running resistive loads in the kitchen. Would never even touch 200A, I know that.
Many people around here are able to get 300-350A services if they indicate they are using all electric loads which is an instant 100A demand for heating a home. I however, do not heat with expensive electric power...
Flickering lights on circuit with low voltage and line voltage bulbs davidwiesel Electrical 4 04-18-2011 08:54 AM
Line Voltage Thermostat Wiring bswigart Electrical 10 11-24-2009 07:10 PM
programmable line voltage therm for fan heat nykije HVAC 1 11-18-2009 09:51 PM
wiring a line voltage programmable thermostat cedar HVAC 0 10-24-2009 10:30 PM
Best Way to Establish Plantings Over Sand flyboy Landscaping & Lawn Care 4 04-07-2009 09:38 AM
