Voltage Reading - Electrical - DIY Chatroom Home Improvement Forum
Old 05-09-2011, 06:58 PM   #1
voltage reading
What should the voltage reading be at the truck's plug? I suddenly do not have full braking on my 5th wheel. When checking the plug with my voltage meter it bounces between 2.88 v to 5.58 v. both with the controller set on 6.0 and when manually moved to 100% on. should it read 12 volts?
beretta is offline   Reply With Quote
Old 05-09-2011, 11:09 PM   #2
Many of the newer controllers only give you an accurate voltage reading with the right load installed. Most RV shops have a special tester that puts the proper resistance on the truck connector so it can measure current/voltage properly.
I would bet your controller is fine but you have a corroded ground wire or bad splice near the brakes on the trailer.
Robo_geek is offline   Reply With Quote
Old 05-10-2011, 02:38 AM   #3
Semi-Pro Electro-Geek
Rewards Points: 2,970
Because of the way modern brake controllers work (pulse width modulation), the only way to accurately measure the braking voltage is with the brakes connected, and using a high-quality RMS voltmeter. No brake connected or a cheap meter will give inaccurate readings.
mpoulton is offline   Reply With Quote
low voltage reading at receptacle 2 ball cane Electrical 5 04-06-2011 12:07 AM
Halogen light fixture voltage reading goingcommando Electrical 10 01-19-2011 09:09 AM
voltage on earth wire Spikeyboy Electrical 13 10-15-2010 11:03 AM
Phantom voltage reading on switch loops jamiedolan Electrical 5 02-09-2009 04:22 PM
Voltage reading off on 220 fuse box robert7361 Electrical 7 04-07-2008 06:18 PM
