-   -   Is voltage rating of 4-pole disconnect switch per pole? (http://www.diychatroom.com/f18/voltage-rating-4-pole-disconnect-switch-per-pole-162449/)
CDragon 11-07-2012 12:26 AM
I have a tankless electric water heater running on two 30-amp 240 volt circuits. I want to add a 4-pole disconnect switch near the heater but I can't figure out if I need a disconnect rated at 120V (because 120V is passing through each pole of the switch) or 480V (because 480V is the total passing through all four poles).
The biggest standard 4-pole disconnect I can find is only rated at 400 volts. Anything with a higher rating seems to only be available as a custom-build special order from various companies. If I need a 480V disconnect, does anyone have a good source?
I've read some sites suggest using two 2-pole disconnects but someone over here interprets a section of the national electric code that seems to imply that's not okay because the two 30-amp circuits aren't coming from separate sources.
zappa 11-07-2012 04:26 AM
There is a 240 volt potential on your switch legs, that's the number to work with.
AllanJ 11-07-2012 05:22 AM
The voltage rating is the smallest maximum voltage sustainable between any two terminals (including the ground terminal) plus a safety margin.
Given two 240 volt branch circuits from the same panel feeding the heater, the maximum voltage between any two of the hot lines or between any one hot line and ground is 240.
Speedy Petey 11-07-2012 06:22 AM
This is NOT true. Post #15 in that thread, along with others, is INCORRECT.
CDragon 11-07-2012 01:14 PM
Wow, thanks for the fast responses!
I may just go with two 2-pole disconnects, but I'd rather use a 4-pole for a little extra safety (no chance of one getting switched off with the other left on). Unfortunately I've only found one 4-pole that looks like it might work here. Does anyone know if that disconnect can be safely mounted on its own, or does it need an enclosure? It seems like I could leave some wire insulation going into the holes but there wouldn't be much distance between the end of each hole and bare wire so I don't know if that meets code. If not, could I just buy a metal box and mount it inside?
I guess another problem is I don't think there's a place for the ground wires to pass through the box. Although I would think the box would have to have a place for the ground to connect to ground the box... If there's a connection it isn't obvious. Maybe the rail it mounts on is meant to be grounded?
jbfan 11-07-2012 02:31 PM
That is a din rail mounted switch and it needs and enclosure.
Just go with the 2 2 pole disconnects.
