Old 09-22-2010, 08:49 PM   #1
Voltage Problem
This evening I decided to install a new light fixture in my backporch and found a voltage problem as described below.
1. Voltage between hot wire and ground, breaker on and light switch off
1 volt.
2. Voltage between hot wire and neutral, breaker on and light switch off
1 volt
3. Voltage between hot wire and neutral, breaker on and light switch on
120 volts.
Why is there 1 volt remaining on the first two when in fact there shouldn't be any? Any help would greatly be appreciated, thanks
H. Bruce is offline   Reply With Quote
Old 09-22-2010, 09:17 PM   #2
nap
You talking to me?
nap's Avatar
Voltage Problem
are you using a digital multimeter (DMM)? If so, you likely have "phantom voltage". It isn't really phantom but an induced voltage with such a low current capacity it is basically disregarded.
Old 09-22-2010, 10:25 PM   #3
" Euro " electrician
frenchelectrican's Avatar
Voltage Problem
Nap have the point if you have ditgal Voltmeter they can pick up ghost voltage by induction of other conductors.
If you have a indentscent bulb hooked up you will read zero as you highlight first two parts.
Merci.
Marc
Old 09-23-2010, 09:41 PM   #4
Voltage Problem
I do not have a digital multimeter, I'm using one with a meter on it. Thanks to both of you for answering. Will I just go a head and install
the new light fixture, but what about that 1 volt? Will it not cause a problem?
Old 09-23-2010, 09:43 PM   #5
Voltage Problem
naw I don't think so as long you hook them up in correct way.
Some of the voltmeter can be supersenstive that why sometime can get false reading.
Merci.
Marc
Old 09-24-2010, 01:14 PM   #6
Voltage Problem
Thanks "frenchelectrican" and "nap" for the information and help I certainly appreciated it. I always thought for induction to be involved the wire had to be in the form of a coil such as a transformer.
I scrolled down the page and see a similar posting or thread ,"small voltage on circuit with breaker off ", by jasonmechler (24 aug 09).
Thanks to all and good afternoon from Eastern Canada.
Bruce
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 12:53 PM
Ceiling Fan Circuit Problem G_S_DB Electrical 1 08-25-2010 07:24 PM
Voltage Low Throughout House timjfisher Electrical 4 08-11-2010 07:34 PM
small voltage on circuit with breaker off jasonmechler Electrical 3 08-24-2009 09:52 AM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
