Old 01-02-2013, 09:20 PM   #31
Voltage on my ground leg
Originally Posted by patrickmcdiver View Post
Problem discovered and solved. There was a short one of the outlet boxes and since there was no return path for ground, it just stayed on the ground leg. Thanks for your help
So the ground was floating? That's kind of what I thought. It occurs to me that having a string of outlets wired with a floating ground is probably more dangerous than no ground at all.
fa_f3_20 is offline   Reply With Quote
The Following User Says Thank You to fa_f3_20 For This Useful Post:
patrickmcdiver (01-03-2013)
Tags
ground, neutral, voltage
Question about small voltage between neutral and ground voodoochile Electrical 3 11-01-2012 09:16 PM
How does grounding work? scyarch Electrical 44 06-12-2012 05:59 PM
Proper way to ground a subpanel chieftaing Electrical 25 04-03-2011 11:22 AM
Adding ground in old home ChaosTheory Electrical 6 06-16-2010 05:02 PM
240 volt load/appliance and ground vs neutral kgize Electrical 7 04-23-2010 12:40 AM
