Voltage On My Ground Leg - Electrical - DIY Chatroom Home Improvement Forum
Old 01-01-2013, 11:29 AM   #1
Voltage on my ground leg
I recently bought a new tv and plugged it in to my cable box upstairs and then plugged the tv into the outlet. Then the tv downstairs went out and something in the main cable connecting equipment to the house (outside) blew up. The cable guy came out and said there was a short to ground in my NEW tv. He went on to say that this was the third one this week.
So, this morning, skeptical of his diagnosis, I checked voltage from the ground plug in the receptacle to the ground (outer metal covering) on my HDMI cable, which was plugged into the cable box. I read 118VAC. Seeing as how I can touch the outer metal covering of the HDMI cable without my hair standing up, I suspect I have voltage on my ground leg.
I have an old house with k&t wiring upstairs, but Romex downstairs. Seeing as how not everything that was plugged in was destroyed (only the stuff connected to CATV) the problem must be in that circuit. However, everything worked fine until I plugged in a new tv upstairs. The other tv was connected exactly the same way.
Im perplexed. Please HELP!!!
Thank you
patrickmcdiver is offline   Reply With Quote
Old 01-01-2013, 11:46 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
IMO this is nothing you'll be able to troubleshoot yourself. You need someone with the tools and expertise to check out your whole system.
Sound like someone replaced some non-grounding receptacles with grounding type and you have a fault somewhere.
The Following User Says Thank You to Speedy Petey For This Useful Post:
patrickmcdiver (01-01-2013)
Old 01-01-2013, 11:47 AM   #3
Master Electrician
Rewards Points: 3,680
You could start by disconnecting EVERTHING on the suspect circuit, measure voltage between hot and neutral, between neutral and ground, and between hot and ground. Neutral to ground should be 0 volts. This is best done with a wiggy or analog meter. Digital multimeters may read phantom voltages.
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
Old 01-01-2013, 11:55 AM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I'm gonna call BS on this one, assuming everything the OP has stated is true.
If you have ungrounded wiring upstairs, you wouldn't read 118V even if the HDMI had voltage on it.
Old 01-01-2013, 12:01 PM   #5
Devil Dog
handyman_20772's Avatar
Rewards Points: 77
Your problem may be with that Knob & Tube wiring, here is a link describing some of the short comings of this wiring. One of which is no safety grounding conductor..http://en.wikipedia.org/wiki/Knob_and_tube_wiring
handyman_20772 is offline   Reply With Quote
The Following User Says Thank You to handyman_20772 For This Useful Post:
Old 01-01-2013, 12:01 PM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 142
Bootleg ground on the wrong wire of the knob and tube?
The Following 2 Users Say Thank You to jbfan For This Useful Post:
mpoulton (01-01-2013), patrickmcdiver (01-01-2013)
Old 01-01-2013, 12:01 PM   #7
just double checked. Romex to rept. upstairs. Ground is def hot. Ground to neutral=118vac, hot to neutral=118vac, ground to hot=8vac.
So I wouldn't actually call it BS so much as an error on my part.
Old 01-01-2013, 12:03 PM   #8
There is some k&t wiring upstairs but only for lighting. recpts are Romex
Old 01-01-2013, 12:17 PM   #9
Best I can tell, right now, someone spiced the romex off the k&t wiring upstairs and obviously did so incorrectly. Those of you who provided actual, useful answers, I am greatly appreciative. You can always tell the professionals.
Old 01-01-2013, 12:21 PM   #10
k_buz's Avatar
Did you find the problem or are you just making assumptions?
Old 01-01-2013, 12:22 PM   #11
Rewards Points: 240
The scenario is plausible if the outlet is not grounded, but the cable is.
I had something sort of like this happen when I was finishing my house. An electrician had done the rough, but then the GC abandoned the job, and I wound up doing the finish wiring myself. One day I noticed that I was getting a buzz off of a light switch in the garage. I stupidly touched a cover plate screw, and it popped me.
Opening the box up, I found that the bare ground was touching the hot screw. "OK", I thought, "that explains why the switch body was hot. But why didn't the breaker trip?" Tracing the circuit back, I found a box where a smoke detector was mounted, where the electrician had not tied the grounds together. Everything on the circuit past that had a floating ground. (Fortunately, it was only a few lights, no receptacles.)
I wonder if something like this has happened to the OP, given the age of his house and the mix of wiring methods: The outlets in question are wired with romex with ground, but it's being fed by K&T or older romex without ground. Therefore, the ground doesn't actually extend back to the panel and therefore is floating. Something shorts to ground somewhere, either in the circuit or in something that is plugged in, and the ground becomes hot.
I'd start by unplugging everything on the circuit. Then test for voltage between a receptacle ground and a known good ground. If there is voltage, there's a hot-to-ground short in the circuit. Take the cover plates off of all the devices on the circuit and look for a bare ground wire touching a hot. If there is no voltage, plug everything back in one at a time, checking for voltage on ground after each one.
Either way, the ground should not be floating. If getting the ground extended back to the panel is impractical, then the circuit will need to be protected by a GFCI.
fa_f3_20 is offline   Reply With Quote
The Following 2 Users Say Thank You to fa_f3_20 For This Useful Post:
Old 01-01-2013, 12:29 PM   #12
Let's see. Well, the romex runs to the knob and tube wiring and disappears under an excessive amount of electrical tape and doesnt come out. It is a short run of romex...maybe 9 feet to the recpt. Im calling it an educated guess. You can call it an assumption.
Old 01-01-2013, 12:35 PM   #13
Thanks, I've gotta go to work but I will definitely try your suggestion tomorrow.
Old 01-01-2013, 12:36 PM   #14
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
[quote=patrickmcdiver;1083884]I recently bought a new tv and plugged it in to my cable box upstairs and then plugged the tv into the outlet. Then the tv downstairs went out and something in the main cable connecting equipment to the house (outside) blew up. The cable guy came out and said there was a short to ground in my NEW tv. He went on to say that this was the third one this week.
Is the receptacle your testing on the knob and tube wiring ?
Is it a 2 prong receptacle or 3 prong?
Is your new tv a 3 prong plug or 2 prong ?
If the receptacle is two prong and your testing to the neutral then it could be wired reverse of normal ..ie.. hot to the neutral side and neutral on the hot side. This would explain the voltage reading to the ground of the HDMI when you test.
If it is 3 prong and a bootleg ground was installed and the receptacle is wired reverse .. if you plug a 3 prong plug into it you would energize the the ground of the tv which would travel to the hdmi cable.
It is very common to see knob and tube wiring reversed on receptacles and in some cases this can cause problems.
The Following User Says Thank You to Stubbie For This Useful Post:
Old 01-01-2013, 12:56 PM   #15
Licensed electrician
Rewards Points: 1,028
The ungrounded K&T should not have been extended.
Tags
ground , neutral , voltage
Question about small voltage between neutral and ground voodoochile Electrical 3 11-01-2012 09:16 PM
How does grounding work? scyarch Electrical 44 06-12-2012 05:59 PM
Proper way to ground a subpanel chieftaing Electrical 25 04-03-2011 11:22 AM
Adding ground in old home ChaosTheory Electrical 6 06-16-2010 05:02 PM
240 volt load/appliance and ground vs neutral kgize Electrical 7 04-23-2010 12:40 AM
