Voltage Measurement Not As Expected On 3-way - Electrical - DIY Chatroom Home Improvement Forum
Old 03-10-2011, 11:40 AM   #1
Voltage measurement not as expected on 3-way
Newbie learning about electricity.
I got a digital multimeter, and have been measuring various devices.
I have a pair of 3-way switches controlling the basement lights.
I measured voltages on one of the 3-way switches.
When the lights are off, I measure 120 volts between the 2 traveller terminals, which is what I expect to see.
With the lights on, I measure 80 volts between the travellers. I get 120 volts between the hot traveller and ground, and I get 13 volts between the other traveller and ground. I get 120 between the common and ground, and 120 between the common and non-hot traveller.
Why do I see only 80 between the travellers when the circuit is on?
Thanks.
bw777 is offline   Reply With Quote
Old 03-10-2011, 01:03 PM   #2
I=E/R
a7ecorsair's Avatar
Why would you expect this? In this case the meter is in series with the lamp filament and the to leads - hot and neutral - but since the meter has a 10 meg ohm input impedance there is no (read very little) current flow.
Thanks.
With the lights on, one traveler is floating so you will have false readings.
a7ecorsair is offline   Reply With Quote
The Following User Says Thank You to a7ecorsair For This Useful Post:
bw77 (03-11-2011)
voltage on earth wire Spikeyboy Electrical 13 10-15-2010 11:03 AM
Voltage in Metal Roof and Gutters TITAN2390 Electrical 4 10-07-2010 07:44 PM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 12:25 PM
Low voltage box question WShawn Electrical 7 08-19-2008 06:22 AM
2 - 900w tansformers on a 15A circuit? tonyBagadonuts Electrical 19 07-20-2008 07:15 PM
