Voltage Drop - Sub Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 02-28-2010, 12:26 PM   #1
I am going to be working on a project where I would like to put in a 100 AMP sub panel in an out building. I have a long run so I need to take voltage drop into consideration (185 ft.). When I look at voltage drop calculators, one of the variables is always volts. I would like to clear up a spot of confusion for me so I do not choose the wrong size wire for the run. The panel would have 240v capability, but the circuits from the panel may be 120v breakers or 240v 2 post breakers. So to calculate voltage drop between my main panel and my new subpanel, do I use 120v or 240v for the calculation?
Thank you in advance.
Moose50000 is offline   Reply With Quote
Old 02-28-2010, 12:45 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 224
Use 240 volt fot the calculations.
Old 02-28-2010, 07:23 PM   #3
Rewards Points: 502
For my 100 amp sub in my barn, which I think was just under 200', I ran 2-2-2-6.
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Moving several circuits to sub panel WoodworkerDave Electrical 2 09-27-2008 03:05 PM
Use a shared nuetral or not? That is the question. Cyndi Electrical 16 05-23-2008 03:59 PM
Will splice cause voltage drop? JPsAlias Electrical 6 05-19-2008 08:09 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 08:37 AM
Voltage Drop between switch and fixtures CaptMike Electrical 1 06-24-2005 10:30 PM
