Old 02-09-2010, 10:15 PM   #1
voltage drop problem
I'm getting a few things wrapped up in my condo for closing, and one of the things I wanted to tackle was the stove resetting almost every time I turn the vent hood on.
Hopefully some electricians can provide some input....
things I found while troubleshooting.
I shut off the power 20A circuit controls fridge stove( gas) and the hood, I pulled down the vent hood and realized it was #14 wire to the vent hood. I pulled the outlet out behind the stove and saw that #12 fed the outlet and the 14 branched off to the vent hood, I also noted that the #14 wire was loose in the wall so this must have been an afterthought installation on the builders part. I connected a new piece of 12-2 to the 14-2 and yanked it through the wall hoping that was the problem... It was not.
I wired everything back up plugged the stove in and inserted my multimeter into the other outlet to check for a voltage drop, and there was quite a drop. There was no consistent drop sometimes it was 1 or 2 volts other times it was 10, 20 and even 30 volt drop! my base reading was 120.1VAC and recorded as low as 90.4VAC
Any thoughts? I'm thinking it may be the motor on the vent hood but Don't know how I would go by checking this.
The house already had a home inspection and there was no mention of this happening to them but I can't in good conscience leave it like that.
naehring2000 is offline   Reply With Quote
Old 02-09-2010, 10:23 PM   #2
joed's Avatar
Loose connection somewhere on the circuit. Could be in any junction box between the problem and the panel. Could even be in the panel.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 02-09-2010, 10:28 PM   #3
no i've eliminated the panel, I used to have an FPE panel and ha the same problem, my electrician said lets wait and see if the new panel fixes the problem, it didnt and here I am. I have 1 other junction for the outlet behind the fridge I will check out it doesnt seem like a lose connection as the stove never resets unless i turn the vent hood on.
Old 02-10-2010, 07:58 AM   #4
Check the neutrals also, including where they are screwed onto the bus bar in the panel. Connections can oxidize and/or work loose; unscrewing a quarter turn and then retightening (not with tremendous force) usually clears the oxidation as well as re-establish any loose connection.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 02-10-2010, 11:45 AM   #5
J. V.'s Avatar
The range hood (#14) and the stove (#12) cannot share the circuit unless you change the breaker to 15 amp.
I would put the range hood on another circuit and depending on the stove requirements (amps) I would get the stove either on its own circuit or another 20 amp circuit.
Check the stoves current requirement on the nameplate.
Old 02-10-2010, 12:14 PM   #6
#14 wire is gone, i replaced it with #12
Another 3-way switch problem. speedster1 Electrical 6 01-16-2010 08:01 AM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 08:48 PM
Voltage drop at thermostat fastback4 HVAC 3 06-25-2009 05:44 PM
Low voltage box question WShawn Electrical 7 08-19-2008 07:22 AM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
