Voltage Drop Calculations And Parking Lot Lights - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 02-20-2013, 06:12 PM   #31
Semi-Pro Electro-Geek
Rewards Points: 2,852
I would expect the ballasts to work fine on the 208V tap. Might want to measure the operating current to make sure it's not higher than expected. If the current is correct, then the voltage is close enough to the design point that the ballast is regulating properly.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 02-20-2013, 06:46 PM   #32
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
The ballasts for the M400 HPS that have the multi voltage option are designed for 120/208/240/277 so if no 208 he will have 240.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 02-20-2013, 07:33 PM   #33
Rewards Points: 14
Originally Posted by al_smelter View Post
I doubt if you have 208 in a small venue like you described earlier. I suspect you are going to need to grow wings [or beg your POCO buddies back out with their bucket truck] to change the taps on the ballasts to 240V.
Yes, it is indeed 208V 3 phase. I went over today and confirmed that myself after hearing the fixtures had been wired for 208V.
Squidbilly is offline   Reply With Quote
Old 02-20-2013, 07:44 PM   #34
UAW SKILLED TRADES
Stubbie's Avatar
Will your local guys know how to wire that up or can you at least show them ?
If poco wired the the lights your likely good there. Do you guys know how to get the 208 volts single phase from the 3 phase panel?
Stubbie
Old 02-20-2013, 10:33 PM   #35
Rewards Points: 14
They already have the black, green, and white wire in place, so we are going to use the white as the 2nd hot leg in combination with a 20A double pole breaker.
Old 02-20-2013, 11:48 PM   #36
UAW SKILLED TRADES
Stubbie's Avatar
Very good ... you should have lights when you power up. Remember HPS takes a while to brighten up so give them around 4 minutes to reach full lumens.
Stubbie
Old 02-26-2013, 09:50 AM   #37
Rewards Points: 14
Just a few side questions as we still try to figure out these lights. I made the changes in the panel and confirmed that 208V was being delivered to the base of the poles. However, still no lights. Hopefully the power company will be out today or tomorrow to check their work.
Is the NEC 215.2(A)(4) informational note No. 2 the only part of the NEC that makes voltage drop recommendations (< 5%).
Also, does the NEC address/restrict the use of colored ungrounded conductors in a 3 phase (208Y120) panel? The panel has black, red, blue with white and green as neutrals and grounds respectively.
Thanks.
