Voltage Drop - Electrical - DIY Chatroom Home Improvement Forum
Old 03-07-2013, 08:40 PM   #1
Voltage Drop
Hello all. I am new to this forum but am very active in several forums. I'm a big believer in them and have saved a lot of time and money using them therefore I am reaching out to the experts here on this one.
Before I posted this, I conducted a search on this forum to be sure I do not re-post something that has already been answered. There were a few bits and pieces I was bale to string together but hope that I can get further help by explaining exactly what I am doing.
I am about to instal low voltage lighting around my driveway. To paint a picture of the layout, imagine a U-shaped driveway with the two entrances running perpendicular to the street. At the opposite end is my house and deck. I plan on running 12 gauge wire from the transformer on my deck in TWO SEPARATE runs, run A and run B.
Run A will total 192 feet with the first light at about the 40 foot mark. I will be putting a total of 6 spreader lights that are each 10 watts and one spot that will be 50 watts.
Run B will also begin at the transformer on the deck and will be a total of 228 feet of 12 gauge wire. The first light will be at approximately the 55 foot mark. Again, on this run I will be using 6 spreader lights at at 10w a piece and one spot at 50w.
I have calculated run A to have an approximate 1.53 volt drop. Run B will have a 1.82 volt drop.
My question is whether or not there will be sufficient power to all the lights on each run assuming that I utilize a multi tap transformer and use the 14 volt hookup for run A and a 16 (or the next higher) for run B. My main concern is that run B is such a long run, that even if I compensate for the voltage drop by using the higher hookup, there will still be a difference in the brightness of the two strings of lights.
Any advice or suggestions would be greatly appreciated.
Thank you
vtl382 is offline   Reply With Quote
Old 03-07-2013, 08:53 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Thank you
I generally run all my lights as home runs, all with the same length of cable... some of your lights are small wattage though... so IMO, i would run home runs to just the 50 watt loads, and just join the 10 watt loads together as in row (a) and (b) for a total of (4) home runs... This will allow you to adjust the voltage settings accordingly, and you should shoot for 11v at the fixture to maximize lamp premature failure and brightness.
Old 03-07-2013, 08:58 PM   #3
Thanks!
So if I combine the two runs into one run with all 12 T3 lamps (120 watts) on it, it will not affect the brightness due to voltage drop? That would be 120 volts on 351 feet of wire. I calculate a 5.6 volt drop on that long of a run.
Old 03-07-2013, 09:01 PM   #4
Stickboy,
My fault, I misread. Four runs, not tow. Got it! Makes sense!
Old 03-07-2013, 09:22 PM   #5
E2 Electrician
Stickboy,
Yep... I think you will be okay with this scenario...
Old 03-07-2013, 11:13 PM   #6
Rewards Points: 948
Are all the lights at the end, or are they spread out along the run?
If you run 14v, the first couple lights won't last very long.
Toller is offline   Reply With Quote
Old 03-08-2013, 01:07 AM   #7
Run A will total 192 feet with the first light at about the 40 foot mark. I will be putting a total of 6 spreader lights spaced along the next 140 or so feet of this run.
Run B will also begin at the transformer on the deck and will be a total of 228 feet of 12 gauge wire. The first light will be at approximately the 120 foot mark. Again, on this run I will be using 6 spreader lights spaced along the remaining 100 or so feet.
Does that answer your question? I understand that I will need to account for voltage drop, but how can I do so without running too much current to the first few lights? The problem is the placement of the power source. Without tunneling under the driveway (which would be perfect but not on my wallet) I have to begin the run at the nearest power source which is approx 40 feet or so from the first light. Then run the remaining LONG wire on each run. Make sense?
Thanks for all the input! It is really going to help.
Long Run Voltage Drop i_need_help Electrical 10 02-05-2011 11:53 AM
2 - 900w tansformers on a 15A circuit? tonyBagadonuts Electrical 19 07-20-2008 08:15 PM
Will splice cause voltage drop? JPsAlias Electrical 6 05-19-2008 08:09 PM
Voltage Drop Issues sushiboy Electrical 12 04-03-2008 10:01 PM
Voltage Drop between switch and fixtures CaptMike Electrical 1 06-24-2005 10:30 PM
