Voltage Drop - Electrical - DIY Chatroom Home Improvement Forum
Old 02-11-2008, 06:10 PM   #1
voltage drop
We've experincing voltage drop on some of our lights and outlets since after a heavy rain last week. I need some advice on who to call.
I check the feed going into the distribution panel. One side was 143 volts and the other 98 volts. Should I called th power company or the an electrician?
HandyAl is offline   Reply With Quote
Old 02-11-2008, 06:13 PM   #2
Electrician
You have a neutral problem call either an electrician or your poco ASAP!!!! Either or but HURRY!!!
chris75 is offline   Reply With Quote
Old 02-11-2008, 11:10 PM   #3
Union Electrician
goose134's Avatar
Al, I agree 110% with Chris. Neutral. Bad. Electrician first, POCO second.
goose134 is offline   Reply With Quote
Old 02-11-2008, 11:13 PM   #4
Electrician
His computer is probably cooked by now...
Old 02-12-2008, 02:47 PM   #5
Voltage drop UPDATE
Power company came out today and found a bad neutral in the drop coming from transformer to the house. They're got a temporary copper line running on the ground until they can get a work order to bury a new drop.
Old 02-12-2008, 04:38 PM   #6
Electrician
Dont forget, most POCO's are liable for any damage to your house so make records of the events if anything gets damaged...
Old 02-12-2008, 09:03 PM   #7
Union Electrician
goose134's Avatar
Good point Chris. Glad this was taken care of. These types of things get ghastly and most people don't catch them until it is too late.
Old 02-13-2008, 06:50 PM   #8
The only thig I can see that went bad is one CFL bulb.
Help! Need way to locate low voltage light cables Johnboy555 Electrical 17 01-13-2017 02:34 PM
Questions about major voltage drop. jdh321 Electrical 6 11-13-2007 08:50 PM
Low voltage to vacuum l.schrankel@comcast.net Electrical 2 03-04-2007 10:38 AM
Voltage Drop Manuel6 Electrical 1 01-16-2007 06:20 PM
Voltage Drop between switch and fixtures CaptMike Electrical 1 06-24-2005 10:30 PM
