Old 04-23-2012, 07:11 PM   #1
voltage drop
Hello All,
Hopefully I am posting this in the correct forum!
I am new to the forum and I have a question I would like to pose.
I am trying to make an extension cable for my telescope hand control.
I have had good results with the 25' length but it is to short . So I made another one 50' in length but it give me connection error codes. The cable is correct as it worked for a while .I am using an rj12 6pin connector with cat5 cable(24awg). The power supply is 12V DC with 2.5 amps running on house AC.
The question is: If I put a different power supply on that is 12v DC using 5.0 amps will the increase in amperage effect the DC current flow?
Thanks,
Don
dragon86 is offline   Reply With Quote
Old 04-23-2012, 07:31 PM   #2
voltage drop
Thanks,
Don
Substituting a bigger power supply more amperes capability will accomplish nothing regards voltage drop on a longer length of wire.
You need heavier wire for the longer distance of 12 volt run. Now if you can run 120 volts closer to where the telescope is so the 12 volt line is much shorter then you will not have the voltage drop problem.
For the same piece of wire the number of volts dropped (lost) is the same for a given number of amperes regardless of the voltage. Losing 3 volts out of 120 almost never causes a problem while losing 3 volts out of 12 almost always causes a problem.
For electronic equipment do not try to use a higher voltage power supply given the distance to overcome voltage drop problems. The voltage will vary as the equipment amperes draw varies and can burn out the equipment.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
AllanJ is online now   Reply With Quote
Old 04-23-2012, 08:12 PM   #3
Average Joe/ex-Navy IC3
gregzoll's Avatar
voltage drop
You can also set up a battery cart with a deep cycle battery to power, if you are using the telescope in places that you may not have access to power (ie unable to drive your car or truck out there, or unable to pull a 120vac leg outside.).
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 04-24-2012, 02:01 AM   #4
JOATMON
ddawg16's Avatar
voltage drop
Try Cat 6 cable. It uses 22 AWG wire....the voltage drop will be less.
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
The Following User Says Thank You to ddawg16 For This Useful Post:
zappa (04-24-2012)
Old 04-24-2012, 05:43 AM   #5
voltage drop
This sounds like something good to try. You mentioned "connection error codes" so there is a possibility that the DC voltage drop isn't your problem. Do you know which protocol your controller uses? If it is unbalanced RS-232 you may be getting close to the maximum length and the larger wire might help in this case also.
zappa is offline   Reply With Quote
Old 04-24-2012, 08:22 AM   #6
voltage drop
An added thought if you have enough spare wires and are good at soldering and working with small wires. It's a little hackish but you could double up on your important wires right behind the RJ connector but only connect with the mating twist. Two each for power and ground if voltage drop is your problem. If you are having comm errors and it is an unbalanced protocol then doubling up with the same twist will help that issue as well. Twisted wire is not the best to use with an unbalanced circuit but doubling up will essentially make it act like a single wire.
Long Run Voltage Drop i_need_help Electrical 10 02-05-2011 11:53 AM
2 - 900w tansformers on a 15A circuit? tonyBagadonuts Electrical 19 07-20-2008 08:15 PM
Will splice cause voltage drop? JPsAlias Electrical 6 05-19-2008 08:09 PM
Voltage Drop Issues sushiboy Electrical 12 04-03-2008 10:01 PM
Voltage Drop between switch and fixtures CaptMike Electrical 1 06-24-2005 10:30 PM
