Voltage And Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 04-08-2011, 09:32 AM   #1
voltage and breaker
Why am I getting a reading of 47 volts when I have the breaker off,
rpeschel is offline   Reply With Quote
Old 04-08-2011, 10:08 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,216
Most probably you are reading phantom voltage with a digital meter. Use an incadescent lamp to load the circuit and remeasure.
Coastal South Carolina
Old 04-08-2011, 11:23 AM   #3
Rewards Points: 174
Get one of these and you will not have to worry about phantom voltages. Every DIY'er should have one.
Old 04-08-2011, 09:48 PM   #4
Missouri Bound's Avatar
voltage
If it's true voltage, you may have two circuits sharing the same neutral. Keep the meter on the circuit and try shutting off other breakers, one at a time.
low voltage reading at receptacle 2 ball cane Electrical 5 04-06-2011 12:07 AM
Voltage in Metal Roof and Gutters TITAN2390 Electrical 4 10-07-2010 07:44 PM
small voltage on circuit with breaker off jasonmechler Electrical 3 08-24-2009 08:52 AM
Breaker problem jdhar Electrical 11 06-10-2009 01:18 AM
feed back voltage when using double breaker sluggermike Electrical 59 09-20-2007 02:37 PM
