Volt/phase To Amp/volt - Electrical - DIY Chatroom Home Improvement Forum
Old 04-25-2013, 03:36 PM   #1
volt/phase to amp/volt
Is a 600 volt three phase service different than a 100 or 200 amp 120/240 volt service?
leigh trethewey is offline   Reply With Quote
Old 04-25-2013, 03:41 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 232
Yes.
120/240 is usually a single phase.
600 volt 3 phase is rare in some parts of the states
Old 04-25-2013, 06:24 PM   #3
Civil Engineer
Rewards Points: 4,568
600V three phase is relatively common in industrial uses, typically seen where large motors are in use. As noted previously, 120/240 is single phase service, properly termed split phase.
Daniel Holzman is online now   Reply With Quote
Old 04-25-2013, 06:50 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,874
They are very different in many ways.
Why do you ask?
Old 04-25-2013, 07:19 PM   #5
joed's Avatar
Rewards Points: 11,998
600 volt three phase is the standard industrial voltage used in Canada. In US it more commonly 480 volt three phase.
Old 04-25-2013, 07:58 PM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 1,122
That 'was' about to be my response....
ddawg16 is online now   Reply With Quote
Old 04-25-2013, 08:33 PM   #7
Idiot Emeritus
Rewards Points: 1,492
The two systems are different in almost every way.
Panels and breakers are different, switches and receptacles are different, the loads they serve are different, about the only thing that's the same is they both can use the same wire (but usually different colors).
If the service is 600 volt, the only way to use 120 or 240 volt equipment is with a transformer.
Rob
micromind is offline   Reply With Quote
Old 04-26-2013, 08:39 AM   #8
Rewards Points: 1,442
Hmmm. So that's why 600 volts is a common rating for electrical components including switches and wire. (Other common ratings are 250 and 125 volts). You can use higher voltage rated wire for lower actual voltages.
For series circuits (rare except for Christmas lights) components must be rated for the supply voltage, not the voltage of an individual lamp or component.
For "services" even the 600 volt 3 phase has an amperes rating such as 100 amps. The amperes rating is dictated by wire and meter and component current handling capability, and electric companies offer a small finite number of service choices. The amperes rating of a service is the number of amperes that may be drawn from any one leg or phase.
