#1 |
Volt Meter Testing Question
I have a question about testing with a volt meter. While I was at work I was watching someone test with their meter inside of a panel. This panel had AC and DC circuits. Obviously with one lead you would have to go to the positive wire, but for the other wire he would put his lead on either the ground or sometimes the negative wire. On a DC system, would you test the + to ground or would you test from + to -? I guess I have the same queston from AC also.
#2 |
Electrical Contractor
For DC he would be checking the Negative - and the Positive + For AC he would be checking between the Hot wires and neutral or ground.
Could have also been checking for resistance or load with amp meter. |
#3 | |
Semi-Pro Electro-Geek
Volt Meter Testing QuestionQuote:
#4 |
Experienced
I work in panels all the time with both DC and AC, the DC is only 24V and is used for analog control circuits. The DC has no reference to ground and must be measured + to -.
Mark
When its all said and done there is usually more said than done To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| The Following User Says Thank You to Jackofall1 For This Useful Post: | Hardway (02-19-2012) |
#5 |
Thanks for the replies guys. I work in a factory. All the machines have AC and DC in the panels with multiple voltages. I guess I am confused on how the components would have no reference point to ground since the components are mounted on strips of aluminum called din rail. The din rail is mounted on to the backplane of the panel which in essence the panel must be grounded. So if I have a good grounding point for DC could you check off of that?
#6 |
It was a dark and stormy
There are 'common mode' and 'differential mode' methods of supplying power, as well as signals. There are also balanced and unbalanced setups. There might be a Web tutorial somewhere.
#7 |
Typically the panels have a power supply with a 120v coming in and it gets knocked down to 24v. Acts as a transformer or is. I know what everything is in the panels, just dont understand the testing methods.
#8 |
I also work in a lot of panels that have both AC and DC but there are different configurations. What you are describing sounds like the DC negative is connected to the chassis (panel) ground. Sometimes the DC negative is not connected to chassis ground and in that case you would have to measure directly to a + and - bus.
#9 |
Thank u
#10 |
When working with small electronics I work with testing many different voltages AC and DC.
#11 |
I see: when you say "panel" you're not referring to a "panel board" containing buses with circuit breakers mounted on them, but to a control cabinet containing contactors, PLCs, etc. Those certainly can contain AC and DC wiring. Some industrial control protocols do not use ground-referenced signals to avoid interference. They use two (or more) wires isolated from ground to carry information.
| Display Modes | |
| Height of meter box | Arky217 | Electrical | 4 | 05-23-2011 11:56 AM |
| 220 Volt Electrical Wiring Question ... for light ??? | shotguns | Electrical | 11 | 05-21-2011 10:03 PM |
| 240 volt circuit question | dukeofsolidsrfc | Electrical | 6 | 02-28-2010 03:00 PM |
| New clamp meter question | Chevyman30571 | Electrical | 18 | 02-22-2010 12:35 AM |
| Pressure Testing the Filter system, What meter to get? | zootjeff | HVAC | 1 | 07-12-2007 12:58 PM |
