Voip Over Regular Land Line - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-01-2009, 09:45 AM   #16
Rewards Points: 508
Send a message via AIM to theatretch85
Originally Posted by kirridam View Post
I checked almost all the phone jack and they are using only the blue/white and blue wires. All the other wires are not being used. See attached image.
So does it mean that I have to connect all the blue/white wires from all the 9 cables together and all the blue wires from all the 9 cables together?
That's too bad that the installer was that lazy that he didn't hook up the second line; it really isn't that hard and doesn't take that long to hook up 2 more wires.
Yes, you will just need to connect all the blue wires together and all the blue/white wires together. If you are still having issues, I would double check to make sure the phone you are using works on the voip line by plugging it directly into the voip adaptor just to check it out.
theatretch85 is offline   Reply With Quote
Old 02-01-2009, 02:22 PM   #17
theatretch85,
It worked!! I'm able to connect to any phone jack and make/receive calls. Thanks a lot for your patience and help. The main reason why I wanted this to be done is b/c DishTV requires a phone connection to the receiver. Since I didn't have any, they charged me $5.00/month! Now I can save that money!! Thanks a lot for your help!!
kirridam is offline   Reply With Quote
Old 02-01-2009, 02:37 PM   #18
Rewards Points: 508
theatretch85,
Hey I am glad its working for you now. What was the problem/what did you have to do to make it work? It might prove to be helpful for anyone else in a similar situation that may stumble upon this thread in the future.
Old 02-01-2009, 02:49 PM   #19
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,374
Since you are not connected to the telephone company, couldn't you simply plug the vonage VOIP box into any telephone jack? Any telephone that you plug in to any other jack should work on the VOIP network.
Clutchcargo is offline   Reply With Quote
Old 02-01-2009, 02:55 PM   #20
Rewards Points: 508
Originally Posted by Clutchcargo View Post
Couldn't you simply plug the vonage VOIP box into any telephone jack?
Check out the OP on this thread, he is dealing with a new house and none of the jacks were wired to a telephone company. He has 9 pairs of wires exiting the side of his house with no telco box to wire them up in (the builder did not wire all the jacks in the house together). It just meant he had to wire the pairs together so that the jacks were all interconnected, and then yes it works such that you can plug the vonage line into any jack along with a phone into any jack.
I have yet to see a house wired this way, normally all the pairs in the house are tied together in a central location, and just one pair runs to the outside of the house where it ties into the telco connection. My house here they did a lot of daisy chaining with the phone jacks; poor design but its also an older house too.
Old 02-01-2009, 06:49 PM   #21
The last time I tried it, I only connected the blue wires together. This time I connected all the blue/white wires together and all the blue wires together. That pretty much solved the problem.
As for all the other wires, I just left them as it is. Didn't inter-connect any of the other wires.
Thanks for your help!
k
Solar lighting vs. regular for outdoor hotwired Electrical 8 08-10-2008 02:07 AM
Question about regular & high speed USB's mact60 PC Repairs & Upgrades 3 08-01-2008 05:55 PM
SnapStone vs regular tile nancy-max Flooring 3 05-12-2008 03:32 PM
Stamped and regular concrete-How much $ dc1212 Building & Construction 6 03-24-2007 08:24 PM
Replacing regular glass with low-e in vinyl frame. Doug Crf Building & Construction 1 10-02-2006 06:31 PM
