Violation? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-18-2009, 06:09 AM   #16
the Musigician
DangerMouse's Avatar
Originally Posted by Speedy Petey View Post
I agree, WHY?
Completely unnecessary and wasteful.
When I see this to me it screams DIY'er who didn't know what they were doing.
unnecessary and wasteful? not to me.
if and when something trips, i want to be able to follow the cord back to the culprit. i got a box full of brand new gfci's for less than regular outlets at auction so i'll be using them any/everywhere!
DM
Old 05-18-2009, 06:57 AM   #17
Bigplanz's Avatar
Rewards Points: 912
Originally Posted by DangerMouse View Post
if and when something trips, i want to be able to follow the cord back to the culprit. DM
I have two in my garage, for the same reason. I wanted to make sure the whole circuit wouldn't go down if one tripped. In the basement, though, I have one GFCI protecting all the outlets in the basement office. I used the little stickers on them.
Bigplanz is offline   Reply With Quote
Old 05-18-2009, 09:09 AM   #18
Originally Posted by Bigplanz View Post
Four inch max spacing
Because 90% of the heads of little kids of a certain age will not go through this spacing.
Old 05-18-2009, 10:33 AM   #19
Rewards Points: 2,350
Oh, they'll go. You just have to push them really hard...
Old 05-18-2009, 11:49 AM   #20
You bad, you bad. . .
Old 05-18-2009, 12:02 PM   #21
Almost every outside outlet I have is on a seperate circuit & GFCI
All the GFCI's (blank face) are in a panel in the basement
But that is mainly due to my Christmas display
I think the problem comes in when the GFCI's are not near the outlet that they protect
Old 05-18-2009, 12:53 PM   #22
This is an interesting dilemma.
You could save money on GFCIs by having very few far upstream and then you have to go hunting for them at $X/hr when an outlet goes dead because you didn't make or couldn't find the "outlet map" for your house. But-there are not many to look for.
Or you could have one at every necessary outlet and spend more on GFs and not do the hunting or the outlet map.
Old 05-18-2009, 01:06 PM   #23
Rewards Points: 506
Send a message via AIM to theatretch85
Or you get some idiot who hides a GFCI outlet behind a shelf or cabinet in the garage so that you cant find it. Its funny to see how many people have come here with outside outlets not working and it turns out to be a hidden GFCI outlet that is tripped.
theatretch85 is offline   Reply With Quote
Old 05-18-2009, 01:10 PM   #24
That's exactly what I mean
Each bathroom has it's own circuit & GFCI
Only 1 GFCI on the bathroom that feeds the other outlet
Kitchen - I'll have 3 circuits - 3 GFCI's
One on one wall - will feed a 2nd outlet
Then next wall - will feed a 2nd outlet
Then a 3rd GFCI - may feed another outlet
I do have a basement GFCI that feeds an outside outlet
From when we 1st moved in I needed more power for Christmas
There is a point when that extra $3 for another GFCI really pays off.
Old 05-18-2009, 08:17 PM   #25
Idiot Emeritus
Rewards Points: 1,492
I usually use dedicated GFIs in commercial/industrial. About the only exception I can think of is a double duplex. I'll feed-through to the adjacent recept., but not to one in another box.
Cheap resi, I'll put one in the garage, and feed-through to the rest of the garage, outside recpt.s, HVAC, crawlspace, etc. I've always run dedicated 20 amp to bathrooms, so they get their own. The two kit circuits have one GFI on each, then feed-through. If I put the fridge on one of the kit curcuits, it's ahead of the GFI.
High-end resi, (and my house) everything that's required to be GFI gets its own GFI, except the kit circuits. They feed-through.
Rob
micromind is offline   Reply With Quote
Old 05-18-2009, 08:27 PM   #26
Chances are the first outlet on that circuit is a gfi, it may be in your garage.
tbishop is offline   Reply With Quote
Old 05-18-2009, 08:39 PM   #27
There's a simple test to determine whether the particular receptacle has GFI protection. (sorry for stating the obvious. But I never heard or read it mentioned by anyone [else] !
Insert a "pigtail socket" into the "hot" and "grounded" lead instead of the "hot" and "neutral". If the "whatever" (breaker or receptacle "test" button (anywhere in the area) trips, you have GFI protection. Usually, when installing a GFCI receptacle, there come along, in the box, about 6 stickers which state "this outlet is gfci protected" on all the outlets downstream of the GFCI recept. I'm not sure if this is a NEC requirement, but is certainly helpful!!!
spark plug is offline   Reply With Quote
Old 05-18-2009, 08:45 PM   #28
An off-topic comment; On your slogan "I am a Pirate, but 200 years late"! Well, Piracy is coming back in style!!!
Old 05-18-2009, 09:00 PM   #29
It certainly is...
building permit violation Austn General DIY Discussions 30 08-24-2010 06:00 PM
Only 1 inspection violation to correct-HELP! DragonInspector Remodeling 1 04-09-2009 12:15 AM
Lights in same joist space with water pipes - Code violation? jweller Electrical 2 03-15-2009 02:02 PM
Building code violation fetzo Building & Construction 18 03-22-2008 03:42 PM
