#1 |
the Musigician
Violation?
isn't this a violation?
i thought ANY outlets near water source had to be gfic? tnkx DM
[SIGPIC][/SIGPIC]Click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. to see some of my original magic tricks and trick boxes! |
#2 |
Saftety First!
Violation?
Are you sure that they are not GFCI'd?
Could be a GFCI breaker or a GFCI recept that they are loaded off of. Did you check in cabinet under sink? |
#3 |
Electrical Contractor
Violation?
It has nothing to do with water. Counter top receptacles require gfci protection.
Are they protected by a breaker?
Yes I am a Pirate, 200 years too late. "Jimmy Buffett" |
#4 | |
It was a dark and stormy
Violation?Quote:
The water removes the current-limiting benefit of the resistance of dry skin, as do voltages >600v. Last edited by Yoyizit; 05-17-2009 at 05:12 PM. |
#5 | |
Licensed Electrical Cont.
Violation?Quote:
The code also says "GFI PROTECTED". Not "must be GFI". So those receptacles most likely are either off a GFI breaker or loaded out from a nearby GFI device, as the others have said.
Sometimes I feel like if I answer any more questions it is like someone trying to climb over a fence to jump off a bridge and me giving them a boost. |
#6 |
the Musigician
Violation?
the one with the switches is gfci, so maybe they're strung from it? didn't think of that.
this is new const. btw. (not my place) DM
#7 |
Res Ipsa Loquitur
Violation?
As it is new contruction, and if done properly and inspected- these outlets are highly likely to be GFCI protected- (probably didn't bother with the stickers!) I wired my kitchen like this- 2-20a circuits along the counter being fed by an initial GFCI for each- all the rest are regular outlets but protected by the first in the circuit.
Did you ever stop to think, then forget to start again? |
#8 |
Idiot Emeritus
Violation?
Trip the GFI, and see what still works.
Rob |
#9 |
Violation?
You can check for GFCI protection.
With a http://images.lowes.com/product/conv...64481000md.jpg and a small incand bulb, 10w or so, run one wire into the short outlet slot and the other into the ground slot. The light will go out and you'll hear a click somewhere in the house. |
#10 | |
Violation?Quote:
#11 |
the Musigician
Violation?
not my home, so i don't really care. i was just curious.
personally, i think i'd use individual gfci's for each. the outdoor balusters were also more than 4" spaces between. THAT is wrong, no? DM
#12 |
Xtreme DIY'r
Violation?
I've never seen the stickers anywhere
Except for the ones in my own house that I put up |
#13 | ||
My License Ain't 4 Sale..
Violation?Quote:
#14 |
Violation?
I agree, WHY?
Completely unnecessary and wasteful. When I see this to me it screams DIY'er who didn't know what they were doing.
| Display Modes | |
| building permit violation | Austn | General Discussion | 30 | 08-24-2010 06:00 PM |
| Only 1 inspection violation to correct-HELP! | DragonInspector | Remodeling | 1 | 04-09-2009 12:15 AM |
| Lights in same joist space with water pipes - Code violation? | jweller | Electrical | 2 | 03-15-2009 02:02 PM |
| Building code violation | fetzo | Building & Construction | 18 | 03-22-2008 03:42 PM |
