Violated Rule One - Electrical - DIY Chatroom Home Improvement Forum
Old 05-13-2008, 04:49 PM   #1
Violated rule one
We are in the prosscess of changing out the celing fans in our house and I violated rule one. REMEMBER WHERE THE WIRES WERE CONNECTED.
We had two fans in the L/R power was controled by one wall switch and fan speed and lights were controlled by internal pull switches. I have running from the switch to the first fan one Black one White one red and a bare ground wire. Then from that fan to the next are the same wires.
The new fans have remote control. I BELIEVE that I do not need the red for the new instalation it was for either the fan or the light on the old one. Now they are controled inside the remote control all power frrom the black and white circuit. Does this sound correct to you experts?
Bob G is offline   Reply With Quote
Old 05-13-2008, 06:23 PM   #2
Licensed electrician
Rewards Points: 1,754
You need to figure out if the red or the black is the switched hot. The other should be the constant hot.
If you wire to the switched hot you will need to leave the switch on for the remote to work. Or wire using the constant hot and the switch will not do anything.
Cap off whichever wire you do not use.
Old 05-13-2008, 06:45 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,970
Actually Rule #1 is Kill the power!
Rule #2 is remember the wiring.
rule of thumb for tamping backfill elementx440 Remodeling 5 05-30-2013 11:46 PM
Subpanel installation in outbuilding fls Electrical 19 03-16-2008 02:19 PM
water hearter rule 1121 SCAQMD jerry1967 Plumbing 3 10-16-2007 07:55 PM
