Vinyl Siding Light Fixture Mount - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-16-2013, 04:33 PM   #16
Oso954's Avatar
Rewards Points: 1,646
The size listed by home depot is incorrect.
With a 4 inch center hole, that product is about 6x6.
Oso954 is online now   Reply With Quote
Old 01-17-2013, 02:03 PM   #17
Originally Posted by AandPDan View Post
The light would get mounted to the box in those "other" blocks.
If this is a new installation, check out these:
http://www.homedepot.com/buy/arlingt...l#.UPcH5R1WJNE
You mount the block to the siding and then the fixture mounts to the block. No box needed.
Cannot do it that way because of the type of siding I have.
Weekend Warrior DIY is offline   Reply With Quote
Old 01-17-2013, 07:12 PM   #18
Licensed electrician
Rewards Points: 1,876
What siding do you have?
Old 01-18-2013, 07:36 AM   #19
It's beaded siding, as far as I was told and can tell. MY contractor is (unavailable) to tell me more.
Old 01-18-2013, 07:39 AM   #20
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
I like the Arlington mounts Jim recommended.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 01-18-2013, 01:42 PM   #21
The Arlington boxes work with a wide variety of siding types.
Old 01-18-2013, 02:09 PM   #22
Jim, I don't doubt that, but Home Depot, Lowe's or the local siding/roofing supplies don't carry anything that would fit beaded siding that would go on after the siding is already up. If you can find a specific Arlington Box that goes with Beaded Siding, I'm all ears.
Old 01-18-2013, 03:45 PM   #23
Look in the link above. The flanges can be removed if you need to retrofit.
Vinyl Siding Not Locking In Place Konfrst Building & Construction 13 11-17-2009 09:40 PM
emergency vinyl siding installation question!!! diy'er on LI Building & Construction 9 08-13-2009 11:16 PM
Vinyl Siding Versus Painting Asbestos freedom_fighter Remodeling 3 02-27-2009 10:35 PM
Vinyl siding over cedar siding dbldee20 Remodeling 8 02-21-2009 07:06 AM
foam back siding vs. reg vinyl siding marnic Building & Construction 3 02-16-2009 07:48 AM
