Vinyl Siding Light Fixture Mount - Electrical - DIY Chatroom Home Improvement Forum
Old 11-17-2009, 10:34 AM   #1
Rewards Points: 518
Vinyl siding light fixture mount
Are there any vinyl siding fixture mounts that don't require you to install them prior to vinyl siding going on(or without having to remove the siding)?
I installed a fixture for a neighbor who cut a really oversized jagged hole in the siding. I also had to use a box extender to accommodate the amount of wires he wanted to run through this fixture far from water proof. The box sticks out 1 inch which is perfect for most of the "J" blocks but I've already spent enough time helping and I don't want to start pulling his siding off next.
n0c7 is offline   Reply With Quote
Old 11-17-2009, 01:42 PM   #2
Check out these they work pretty good
http://www.homedepot.com/webapp/wcs/...atalogId=10053
Plumbvoltage is online now   Reply With Quote
Old 11-17-2009, 04:16 PM   #3
Rewards Points: 518
Looks pretty close to what I need. The only issue may be the position of the laps. What if none of them line up with the blocks? Any tips/suggestions for that?
Old 11-17-2009, 05:28 PM   #4
Master Electrician
Grimlock's Avatar
Fill laps with silicone?
Grimlock is offline   Reply With Quote
Old 11-17-2009, 06:25 PM   #5
BUILDER / REMODELING CONT
buletbob's Avatar
u could also try www.midamericacomponents.com for what your looking for
Old 11-17-2009, 06:32 PM   #6
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Plumb came up with a great find in "Mounting Blocks" from Builders Edge
HD only has a few of the blocks
The 'Builders Edge' catalog has three pages of mounting blocks for everything from meters to doorbells. Contact the source to get one that is not on the HD Site.
One of the blocks on P29 of the catalog may used to dress up the first fixture.
http://www.buildersedge.com/pdf/Pro%20Catalog.pdf
The attached pic is from P28 of the catalog.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 11-17-2009, 07:09 PM   #7
Rewards Points: 518
The siding is dutch style and the light fixture does not line up with any of these mounting surfaces according to the measurements. Looks like my only option is to remove the siding and install one from scratch at this point....
Old 11-17-2009, 07:10 PM   #8
Tool Geek
PaliBob's Avatar
BB, Those Blocks you referenced from Mid-America also look good:
http://www.midamericacomponents.com/...s/standard.php
Disclaimer
& Stay Safe
.....Bob Lavery
Old 11-17-2009, 07:31 PM   #9
Tool Geek
PaliBob's Avatar
This is a pic from the Mid-America Site showing an installation using a mounting block. Does this help any?
Disclaimer
& Stay Safe
.....Bob Lavery
Old 11-17-2009, 09:36 PM   #10
I always made my own because I didn't know what these were called and the round trip to get them is almost the same time as making them.
Just stack some Masonite wedges to fit the siding and fasten to a 1x block of wood with beveled edges. Prime, and caulk on all sides except the bottom.
Old 11-18-2009, 12:08 AM   #11
Rewards Points: 518
Thanks for all the advice. In this case, I had to give in and do what I didn't want to - remove the siding and do it from scratch. Turned out great.
Good to know that there are so many varieties of boxes out there, unfortunately the ones that can be installed after siding goes up seem to require that you place them at a precise measurement defined by the laps of the siding.
Old 11-19-2009, 09:50 AM   #12
Licensed electrician
Rewards Points: 1,254
For future reference checkout the WP mounting boxes available from Arlington. aifittings.com
No need to line up with the laps or remove siding. They also have the box built in unlike the others in the links provide that still require a box to be cut-in.
Here is one from Arlington http://www.arlcatalog.com/Siding/Sid...ts%20large.htm
electures (01-18-2013)
Old 11-19-2009, 10:44 AM   #13
Rewards Points: 518
Oooo, those look nice. Thanks, I'll keep them in mind for the next time!
Old 01-16-2013, 02:33 PM   #14
So what would go behind those blocks? What would the light get mounted to?
Weekend Warrior DIY is offline   Reply With Quote
Old 01-16-2013, 03:04 PM   #15
Rewards Points: 746
The light would get mounted to the box in those "other" blocks.
If this is a new installation, check out these:
http://www.homedepot.com/buy/arlingt...l#.UPcH5R1WJNE
You mount the block to the siding and then the fixture mounts to the block. No box needed.
AandPDan is offline   Reply With Quote
Vinyl Siding Not Locking In Place Konfrst Building & Construction 13 11-17-2009 10:40 PM
emergency vinyl siding installation question!!! diy'er on LI Building & Construction 9 08-14-2009 12:16 AM
Vinyl Siding Versus Painting Asbestos freedom_fighter Remodeling 3 02-27-2009 11:35 PM
Vinyl siding over cedar siding dbldee20 Remodeling 8 02-21-2009 08:06 AM
foam back siding vs. reg vinyl siding marnic Building & Construction 3 02-16-2009 08:48 AM
