Vintage Push Button Light Switches. - Electrical - DIY Chatroom Home Improvement Forum
Old 01-12-2012, 12:36 PM   #1
Vintage push button light switches.
I am in the process of a grant for my historic home and the city wants me to get rid of all my push button light switches as they will not pass code. No ground wire. I have metal boxes on all of them. Is there a way to wire them and ground them to pass the code?
Ellen Burton is offline   Reply With Quote
Old 01-12-2012, 12:49 PM   #2
Julius793's Avatar
How is the house wired ac cable, conduit nm?
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-12-2012, 12:56 PM   #3
Rewards Points: 1,448
Not passing code because there are push button switches or switches more than X years old is a separate topic from individual push button switches not passing code or not Underwriters Laboratories listed.
A push button switch will work perfectly well in a grounded metal outlet box. The switch conductors are connected up in the same way as with a modern toggle switch. Special grounding clips that squash between the switch frame (yoke) and the metal box where it is screwed onto can be purchased separately. For plastic boxes, check with your inspector to see whether he will pass a mounting screw, the switch yoke, the special clip, the ground wire from a Romex cable, and the mounting hole in the box all squashed together for an adequate ground.
Another separate topic: Grounding for the branch circuit itself, including grounding of the outlet boxes if metal.
AllanJ is online now   Reply With Quote
The Following User Says Thank You to AllanJ For This Useful Post:
Ellen Burton (01-12-2012)
Old 01-12-2012, 01:18 PM   #4
MarginallyQualified
Rewards Points: 2,464
1) INSIST that they document their assertions.
2) Are the other devices (like receptacles) that actually warrant a ground...
actually grounded now?
Old 01-12-2012, 01:53 PM   #5
Rewards Points: 1,574
These are UL listed and ok in Canada as well:
http://houseofantiquehardware.com/s....category.34/.f
bob22 is offline   Reply With Quote
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 11:40 AM
4 switches control 1 light, power at light thinksnowjob Electrical 5 05-19-2011 09:55 PM
Installed new light switches and now fan/light won't work theemorgandorfe Electrical 2 05-24-2010 11:13 PM
Light switches on/off - and kids mommy78 Electrical 6 08-13-2009 01:03 PM
50+ year old home-all light switches one-way? mudpaw Electrical 13 06-22-2008 02:57 PM
