-   -   Vintage push button light switches. (http://www.diychatroom.com/f18/vintage-push-button-light-switches-129686/)
Ellen Burton 01-12-2012 12:36 PM
I am in the process of a grant for my historic home and the city wants me to get rid of all my push button light switches as they will not pass code. No ground wire. I have metal boxes on all of them. Is there a way to wire them and ground them to pass the code?
Julius793 01-12-2012 12:49 PM
How is the house wired ac cable, conduit nm?
AllanJ 01-12-2012 12:56 PM
Not passing code because there are push button switches or switches more than X years old is a separate topic from individual push button switches not passing code or not Underwriters Laboratories listed.
A push button switch will work perfectly well in a grounded metal outlet box. The switch conductors are connected up in the same way as with a modern toggle switch. Special grounding clips that squash between the switch frame (yoke) and the metal box where it is screwed onto can be purchased separately. For plastic boxes, check with your inspector to see whether he will pass a mounting screw, the switch yoke, the special clip, the ground wire from a Romex cable, and the mounting hole in the box all squashed together for an adequate ground.
Another separate topic: Grounding for the branch circuit itself, including grounding of the outlet boxes if metal.
TarheelTerp 01-12-2012 01:18 PM
1) INSIST that they document their assertions.
2) Are the other devices (like receptacles) that actually warrant a ground...
actually grounded now?
bob22 01-12-2012 01:53 PM
These are UL listed and ok in Canada as well:
http://houseofantiquehardware.com/s....category.34/.f
