Vintage Bulb Burning Out - Electrical - DIY Chatroom Home Improvement Forum
Old 10-11-2012, 09:05 AM   #1
I made a hanging lamp with a porcelain socket, and covered it with an old bottle I cut. I put a vintage edison bulb in the socket. After burning for about 20-30 minutes, the bulb burned out (I tried it twice). The socket and globe were hot. I assume the heat burned the bulb out...
Is it not possible to use a porcelain socket (heat)? Should I use a phenolic socket?
I like the look of the porcelain, is there another option similar to this?
Thanks in advance.
copacetic1 is offline   Reply With Quote
Old 10-11-2012, 09:10 AM   #2
Rewards Points: 13,270
Got a picture.
Not likly it has anything to do with the socket.
Your trying to use a bulb that was never intended to be hung up side down so the support wires are not able to do there job.
Also if this is sealed with no vents it's over heating.
Ever notice every UL listed light fixture has the max rated wattage right on the socket?
Old 10-11-2012, 09:19 AM   #3
There is a check ring and strain relief at the top. Top has no vent, but bottom is open.
The bulb is a 40w
Here is a pic:
Old 10-11-2012, 09:34 AM   #4
Try a fan duty candilabra style bulb.
Old 10-11-2012, 09:45 AM   #5
Rewards Points: 150
Heat rises. Without a vent at the top, heated air is going to collect at the top of the fixture. Would it be possible to drill some holes in the neck of the bottle? Or somehow open up the stopper where the cord comes in.
Or find a lower wattage bulb.
Dave632 is offline   Reply With Quote
Old 10-11-2012, 11:39 AM   #6
Rewards Points: 78
Are you certain the bulb is correct? What is the voltage listed on the bulb (lamp). 40 watts at what voltage?
J. V. is online now   Reply With Quote
Old 10-11-2012, 12:54 PM   #7
The bulb is 40w, 120 volt
Bulb keeps burning out tbbuhner Electrical 2 10-05-2012 05:01 PM
"Final" bulb in parallel circuit brighter than rest. Why? 7.62 Electrical 11 04-30-2012 05:13 PM
Replacing undercabinet halogen bulb with xenon bulb gabbie14 Electrical 10 09-26-2011 11:46 PM
Light Bulb Burning Out GerGa Electrical 1 07-25-2011 11:20 PM
Bulbs keep burning out joelbuckley Electrical 3 11-05-2009 09:23 PM
