-   -   Vintage Bulb Burning Out (http://www.diychatroom.com/f18/vintage-bulb-burning-out-159725/)
copacetic1 10-11-2012 08:05 AM
I made a hanging lamp with a porcelain socket, and covered it with an old bottle I cut. I put a vintage edison bulb in the socket. After burning for about 20-30 minutes, the bulb burned out (I tried it twice). The socket and globe were hot. I assume the heat burned the bulb out...
Is it not possible to use a porcelain socket (heat)? Should I use a phenolic socket?
I like the look of the porcelain, is there another option similar to this?
Thanks in advance.
joecaption 10-11-2012 08:10 AM
Got a picture.
Not likly it has anything to do with the socket.
Your trying to use a bulb that was never intended to be hung up side down so the support wires are not able to do there job.
Also if this is sealed with no vents it's over heating.
Ever notice every UL listed light fixture has the max rated wattage right on the socket?
copacetic1 10-11-2012 08:19 AM
There is a check ring and strain relief at the top. Top has no vent, but bottom is open.
The bulb is a 40w
Here is a pic:
http://i1093.photobucket.com/albums/...h/SAM_1392.jpg
joecaption 10-11-2012 08:34 AM
Try a fan duty candilabra style bulb.
Dave632 10-11-2012 08:45 AM
Heat rises. Without a vent at the top, heated air is going to collect at the top of the fixture. Would it be possible to drill some holes in the neck of the bottle? Or somehow open up the stopper where the cord comes in.
Or find a lower wattage bulb.
J. V. 10-11-2012 10:39 AM
Are you certain the bulb is correct? What is the voltage listed on the bulb (lamp). 40 watts at what voltage?
copacetic1 10-11-2012 11:54 AM
The bulb is 40w, 120 volt
