VFD/Motor Troubleshooting - Electrical - DIY Chatroom Home Improvement Forum
Old 04-16-2011, 10:55 AM   #1
VFD/Motor troubleshooting
Hi all,
I recently bought a VFD and motor for a project for school. I wired it up and the motor appeared to run at high speed but when I applied my load to the motor it just starts up and then peaks at about 60 rpms. As I understand it the VFD should be converting the voltage from single phase 120v to 3 phase 240v.
Here is the motor I bought
http://www.marathonelectric.com/MMPS...p?item=5K36JN2
the VFD
http://www.abb.com/product/seitp322/...78322&ajs=BuId
I changed the DIP switches on the VFD to 60hz and constant torque load.
Any ideas as to why it starts to spin and then peaks out at such a low speed?
Thanks,
RedSooner
Redsooner is offline   Reply With Quote
Old 04-16-2011, 11:52 AM   #2
Rewards Points: 240
Originally Posted by Redsooner View Post
Hi all,
the VFD
Thanks,
RedSooner
Look at page 14 of the user manual for the dip switch settings. Make sure the load setting are correct.
#1 - 60 HZ
#2 - OFF
#3 - Constant Torque!!!!!
#4 - Ignore
#5 - Ignore
#6 - Off. This depends on the speed reference. "On" is for 4-20ma Only.
#7 - Off.
#8 - Off.
Next is your wiring connections. Tell me how you have this hooked up. Are you using a potentiometer?
Dip swith setting #3 must be in CT mode. If it's in VT mode, the problem you describe sounds about right.
Anyway. I need to know the answers before I can help you any further. Also, the user manual is provided for a reason.
Ps..........Why the 2 pole motor? 3600 RPM?
Old 04-16-2011, 12:17 PM   #3
The dip switches match what you wrote. I did go through that owners manual several times trying to figure it out.
I have a heavy duty extension cord with one end cut that goes into the VFD. Then from the vfd I have a 4 wire cord that I plugged into the bottom of the VFD and then to the motor with connection for the low volts diagram (1-7,2-8,3-9 connected to the 3 lines and 4-5-6 wired together, then of course the ground). All the wire is pretty heavy gauge but I don't remember what gauge of the top of my head.
Yes I have a potentiometer from ABB. (on/off, fwd/revse, speed dial).
As far as the ps. This is for a little mockup of a larger design and I just needed the speed. But as you can probably tell I don't know much about motors, ect. so I might have bought the wrong size motor or vfd setup. I don't think its a load problem because it starts to spin from rest. I would think that is when it would need the most torque and after it starts spinning it should be able to ramp up to speed, even if it takes it a little while.
Old 04-16-2011, 01:00 PM   #4
MXer
3 legged dog's Avatar
What are you trying to run at 3450 RPM?
3 legged dog is offline   Reply With Quote
