Vexing Electrical Circuit Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 01-29-2012, 03:34 PM   #1
I have an entire electrical circuit that randomally went out. On this circuit there is a 3 way light, an outlet and a 2 way light. I have pulled the covers off the light switches and the outlet, and tested with a multi-meter there is not any power getting to any of those. I have also cycled the breakers at the breaker panel, tested the power coming out of the breakers, and re-terminated all connections at the breaker panel, and at switches and outlet not working. There is not a GFCI outlet on the circuit. I am not 100% certain on the breaker attached with the circuit in question, because the panel was not labeled when we purchaded our house, but i have narrowed it down to 5 unknowns, over time as I have done various projects around the house. Basically there is power coming out of all breakers in our panel, but no power getting to the lights/outlet. Any suggestions would be appreciated, this is lighting for my entry way/porch, and I am tired of greeting guests in the dark.
skulzer is offline   Reply With Quote
Old 01-29-2012, 03:37 PM   #2
Rewards Points: 13,732
And you did look for a GFI out on the porch or outside someplace?
Old 01-29-2012, 03:43 PM   #3
Yes, the outlet on the porch is not a GCFI, and is on another circuit that currently has good power to it, there are not any other outlets outside.
Old 01-29-2012, 05:35 PM   #4
Licensed electrician
Rewards Points: 1,622
Between what two points did you check for voltage? Black to white and or black to ground? if only black to ground check black to white.
Old 01-29-2012, 05:59 PM   #5
At the outlets and switches I tested between black and white, and at the electrical panel, I tested between black and the commom bar all white were tied to.
Old 01-29-2012, 06:40 PM   #6
joed's Avatar
Rewards Points: 12,904
Did you check the working devices on the circuit? The problem could be a loose connection in a working device on the wire feeding out to the rest of the circuit.
Old 01-29-2012, 06:41 PM   #7
Rewards Points: 506
Start looking for junctions...
jlmran is offline   Reply With Quote
Electrical circuit Opp Electrical 3 12-15-2011 08:03 PM
Is it possible to change Circuit breaker to Buss fuse socket type? njchen24 Electrical 8 08-07-2011 06:27 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Sump Pump Electrical Problem loftezy Electrical 5 09-06-2009 06:14 PM
Electrical "arcing" problem? morden5b Electrical 17 12-17-2008 06:10 PM
