Very Old House That Has 2 Wired Outlets? Please Help! - Electrical - DIY Chatroom Home Improvement Forum
Closed Thread
Old 12-17-2009, 04:41 PM   #1
Very old house that has 2 wired outlets? please help!
I have an outlet box that has 2 copper wires one is black and one is white. I know the whole white on silver and black on brass.
But the outlet that I bought to put into the outlet box requires 3 or 4 lines as shown in it's diagram.
Where can I buy an outlet that will require only one black and one white line and is also a 3 prong receptical?
I can only find a 2 prong one that would work but I want a 3 prong..
if any one can show me a 3 prong outlet that will install into this type of old system then please answer!
redblotoflife is offline
Old 12-17-2009, 04:46 PM   #2
If you only have a 2 wire setup then you need to use 2 prong outlets
OR
install a GFCI & label "no ground present"
-these stickers come with the GFCI
Scuba_Dave is offline
Old 12-17-2009, 04:49 PM   #3
hey
not true Quote:
OR
what is a GFCI and label no ground preset?
also this is not true that I cannot install a 3 prong - there is a 3 prong over in this wall. I just can't install the new 3 prong that I baught over in the other wall
Old 12-17-2009, 04:51 PM   #4
Rewards Points: 320
You may or may not be able to use a three prong receptacle depending on if your wiring system is grounded or not. What type of cable feeds the circuit? Is is bx, or non-metallic (also referred to as romex)? Is there a bare or green conductor in the box?
teamo is offline
Old 12-17-2009, 04:52 PM   #5
Originally Posted by redblotoflife View Post
not true Quote:
OR
Unless you have a ground you can't install a 3 prong outlet
The fact that someone else did does not make it meet code or safe
You need a ground or need to use a GFCI
Where are you located ?
You don't know what a GFCI outlet is ?
Old 12-17-2009, 04:54 PM   #6
break it down please?
it's as I said before - 2 copper wires - one black - one white.
that is all.
No grounding I guess...
what is a gfci? Please break it down as I don't know about electricity obviously.
Old 12-17-2009, 04:56 PM   #7
Sure you can install that, doesn't mean it is right nor safe. If you want to take a chance of harming yourself or someone else do what you have to do, but you have been warned. Get yourself a GFCI and label it no ground present!
Paelectrican is offline
Old 12-17-2009, 04:57 PM   #8
A GFCI is a specific type of 3 prong outlet that can be installed to meet code when a ground is not present
Old 12-17-2009, 04:57 PM   #9
well..
the other thing is I was told that there are 2 prong outlets that do take 2 wiring outlets.
Old 12-17-2009, 04:58 PM   #10
You can still buy & install 2 prong outlets on a 2 wire circuit
Old 12-17-2009, 05:01 PM   #11
If you tie the black to brass and white to silver both receptacles will work if the tabs are not broke.
Having a hard time understanding bear with me.
SULTINI is offline
Old 12-17-2009, 05:02 PM   #12
if I install the gfci?
if I install the gfci 3 prong would I need to install a grounding wire?
Or should I just go with the 2 prong method - would that need grounding also?
Old 12-17-2009, 05:02 PM   #13
I did
I did tie the black to brass an white to silver and did many different variations but it did not work.
Old 12-17-2009, 05:03 PM   #14
You can install the GFCI and use the sticker saying no ground present so people are aware.
Old 12-17-2009, 05:04 PM   #15
2 prong outlets do not have any grounding, not required since its pre-existing
GFCI is 3 prong & does not need a ground so long as it is labelled no ground present
For electrocnics that have a 3 prong plug you are better off installing a 3 wire circuit to plug them in
Closed Thread
Tags
old housing outlets
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
Foam Board on exterior of above grade house Sheldon General DIY Discussions 6 12-08-2009 04:05 PM
Replacing kitch outlets to GFCI jhubert Electrical 7 11-16-2009 07:23 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
