Old 10-19-2012, 09:33 PM   #1
Very frustrating puzzling issue with sconce install
I REALLY need some help as this is so puzzling to me!
Here is a bit of background it case it might help. We live in a 5 yr old house and recently had the bathroom painted.
The painters removed the two (working) vanity sconces to paint but since we hadn't received a replacement we didn't put anything there until now.
The problem is that it isn't working. The sconces called for a certain light bulb, we got them, tried but it wouldn't work. We plugged in the older sconces, they don't work either. With the volt meter is shows that electricity is going through.
I am not sure if they could have messed up something because clearly whomever did it, didn't know what they were doing and cut the wire OF THE SCONCE right at its base (so the sconce was ruined), we noticed that later one.
Now, we tested the lights in the regular switch, they work. We opened up the double dimmer switch that commends the sconces and the ceiling light, it works.
So, it seems like the problem is that not enough electricity is going through but why? The breaker box looks good too. Also, when we first installed the new sconces, we thought they might have been defective or we had somehow the wrong bulbs so we tried several different ones. My husband put it a funky Philipps Candelabra light that was like a 2W or something and that worked but obviously had a very weak light.
Anyone has an idea at all, I am beyond frustrated and have no idea what's going on :/
Any help would be welcome!!!
vouvoune is offline   Reply With Quote
Old 10-19-2012, 10:48 PM   #2
joed's Avatar
If you can tell us what wires are in the boxes and how you connected them up we might be able to help you.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 10-20-2012, 08:27 AM   #3
What was the voltage reading on the voltmeter?
danpik is offline   Reply With Quote
Old 10-20-2012, 09:04 AM   #4
Licensed Electrician
k_buz's Avatar
I can't make heads or tails of the OP. All I know is that their sconces don't work.
Location...Location...Location
k_buz is online now   Reply With Quote
Old 10-20-2012, 09:05 AM   #5
What type are the special sconce bulbs? Are the dimmers compatable with the special sconce bulbs? What type of device are you using to tell if things are working, or electicity is passing through?
daveb1 is offline   Reply With Quote
Old 10-20-2012, 09:20 AM   #6
Electrical Contractor
Someone cut the wires, now the dimmers don't work.
Replace the dimmers with switches and start from there.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
jbfan is online now   Reply With Quote
Old 10-20-2012, 12:59 PM   #7
So sorry if the post didn't make total sense, it is hard to explain in a text.
We finally figured out that even though the meter said the power was going through it just wasn't enough of it to light up the bulbs. So, just like JBFAN said (great summary too!), we worked our way up and ended up changing the dimmers and that was where the problem was.
Tags
light installation
Decking Issue after new roof install CrankyDragon Roofing 12 07-04-2011 11:26 AM
Aude Timer Install Issue Jimmy G Electrical 2 06-30-2010 11:32 PM
Wire Length AFCI breaker install issue 205bhamjim Electrical 5 02-24-2010 03:33 PM
Diagonal Hardwood Install Advice JDeFuria Flooring 7 06-29-2009 04:35 PM
Tub surround install issue OriginalSterm Remodeling 4 09-11-2008 08:11 AM
