Vertical Support Beam - Electrical - DIY Chatroom Home Improvement Forum
Old 04-20-2013, 11:08 AM   #1
vertical support beam
Can I drill through 4 2by4 nailed together supporting a steel beam to make a hole to run 14/2 cable?
Dave57 is offline   Reply With Quote
Old 04-20-2013, 03:56 PM   #2
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 68
You probably can but I find code is too lenient when it comes to this. Personally I would not do it. One hole is not the end of the world, but that later turns into 2, 3 and so on. Find a way to route around it instead. I usually just sand the edges to make sure they're not sharp and go along/around it.
Best method to support new load-bearing beam Pittsville Building & Construction 7 06-10-2011 02:12 PM
Installing a beam with no direct support Ooooooo Carpentry 8 05-08-2011 08:25 PM
What size beam to support loft with 16' between supports paperman Building & Construction 3 10-06-2009 06:40 PM
Crawl Space Beam and Joist Support Questions Fire4Effect Building & Construction 5 06-28-2009 02:07 PM
drilling a support beam sdmotor Building & Construction 1 07-12-2005 11:51 PM
