Vaseline In Light Socket - Electrical - DIY Chatroom Home Improvement Forum
Old 02-11-2009, 11:49 AM   #1
Vaseline in light socket
We had a discussion at work about corroding light sockets in high moisture areas such as crawl spaces or outdoors. One guy who has construction experience, but not electrical, said he puts Vaseline over the bulb threads so he can make sure he can get the buld=b out of the socket easily after if burns out.
Is this appropriate? Are there anti-corrosive lubricants which are more appropriate?
measure thrice is offline   Reply With Quote
Old 02-11-2009, 12:09 PM   #2
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
NO, this is not appropriate. They sell gel made for this at hardware stores. Even Noalox made for AL connections would be more appropriate, but isn't quite correct.
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 02-11-2009, 12:35 PM   #3
Remodeling Contractor
Does the Vaseline jar specify UL approved for installing bulbs? NO.. then by code it is illegal. What you can use is called di-electric grease
Old 02-11-2009, 02:53 PM   #4
joed's Avatar
Rewards Points: 13,338
No Alox has suspended zinc particles. I would NOT use as a lubricant for light bulbs. It is conductive and could easily short the two contacts.
Old 02-11-2009, 05:15 PM   #5
Rewards Points: 266
Don't put Vaseline on the lamp threads!
I did this in our kitchen light many years ago, and as the Vaseline heated up and cooked in the sockets, making it pretty much near impossible to unscrew the bulbs. It also stunk like a dead skunk.
I ended up replacing all 5 sockets (Chandelier fixture), which is what I probably should have done in the first place.
junkcollector is offline   Reply With Quote
Old 02-11-2009, 06:18 PM   #6
Rewards Points: 900
The only electrical use I have ever heard of for vaseline is for car battery terminals, but even there you are supposed to use a specific type of grease, if any.
I have never used a lubricant on a light socket, and have never had trouble removing the bulb. If the bulb wants to break when I am unscrewing it, I just kill the power, and unscrew the remains with a needle-nose plier.
FW
Ultrarunner2017 is offline   Reply With Quote
Old 02-11-2009, 06:56 PM   #7
As Jamiedolan stated earlier, they sell a product specifically for this. I do not know what it is called but do know we use it at work for bulbs that are outdoors and are in hard to reach areas. The lubricant helps keep the rust out and also makes replacing the bulbs a lot easier.
RobandStacey is offline   Reply With Quote
Old 02-11-2009, 07:50 PM   #8
I was walking around Harbor Freight tonight.. and happened to see this on the shelf ($2-3). It made me think of this thread...
DIY_JC is offline   Reply With Quote
Old 02-12-2009, 02:23 AM   #9
I was once told to roll the bulb threads on your forehead to pick up the oils to prevent it from sticking. Not sure how well it works, but from then on I've been doing so.
joey b is offline   Reply With Quote
Old 02-12-2009, 09:00 PM   #10
I try to not screw up.
Pics or it didn't happen!!
2long4u is offline   Reply With Quote
Old 02-12-2009, 09:40 PM   #11
Electrician
ctsmiths's Avatar
Rewards Points: 150
That is TOO funny to be real!
ctsmiths is offline   Reply With Quote
Old 02-16-2009, 12:09 AM   #12
sounds kinda silly, but I don't see any reason why it wouldn't be accurate.
Old 02-17-2009, 06:26 PM   #13
diet suggestions
Should one eat hot & spicy food to produce more sweat and oil on one's forehead?
Old 02-18-2009, 05:04 PM   #14
DIYer
That isn't how it works. UL Listing is voluntary. Also, UL is just a private company, they don't have any special legal rights or anything.
The NEC only requires certain things (and only those certain things) to be "listed" by any organization acceptable to the AHJ. That's usually UL, but it can by any product testing organization. OSHA, for example, recognizes a list of 18 different testing companies.
Gigs is offline   Reply With Quote
Old 02-18-2009, 05:08 PM   #15
Licensed Pro
Actually you roll the bulb in your hair to pick up oils. Works well... at least it did when I still had hair..
Tags
corrosion , light sockets , lubricate
Thermostatically controlled light socket????? beebiz Electrical 28 11-26-2011 03:45 PM
removing broken light bulb from socket? CowboyAndy Electrical 24 01-24-2009 03:03 PM
Light Socket Won't Hold Light Bulb colhollywood Electrical 3 08-16-2008 08:28 AM
Light switch from a double socket ? Terry Collier Electrical 5 04-26-2008 10:39 AM
Switching from light socket to plug - stupid question CGofMP Electrical 5 03-25-2005 09:48 PM
