Vapour Barrier Over Potlights? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-25-2011, 09:40 PM   #1
GBunny
Rewards Points: 71
Vapour barrier over potlights?
I'm having my basement insulated. The contractor has used clear vapour barrier. I thought vapour barrier was black!?
The basement ceiling is being insulated too. The contractor has put vapour barrier across the ceiling, even over the potlights. He has cut a circle out for the bulb to be put in. Won't the heat from the pot light metal box melt the plastic? What if something spills on the floor above, won't the liquid be trapped on top of the plastic and eventually cause mold?
GBunny is offline   Reply With Quote
Old 03-25-2011, 10:00 PM   #2
GBunny
Rewards Points: 71
Vapour barrier around outlets?
I'm having my basement insulated. Is there a special procedure to use when putting insulation near outlets?
Old 03-25-2011, 11:03 PM   #3
I would not put a vapor barrier on the basement ceiling if the basement is a conditioned space. If you want to put insulation in the ceiling to reduce noise from above use unfaced insulation. In terms of the pot lights make sure they are IC rated before you put insulation near the cans. You can use an insulation from Roxul called safe n sound or ComfortBatt that is not combustible and also won't mold/mildew and mice don't like it either. Try the insulation forum as you may find some good advice there.
clydesdale is offline   Reply With Quote
vapour barrier on ceiling of bathroom? wilsonfrench Building & Construction 20 01-29-2012 08:08 PM
Old paper-backed insulation = Vapour Barrier? billyh Building & Construction 3 03-15-2011 08:38 PM
vapour barrier HELP!!!!! 06GT General DIY Discussions 8 02-23-2010 08:01 AM
Roxul without vapour barrier? giannit Building & Construction 8 01-26-2010 04:39 PM
