Vapour Barrier Around Pot Light Box - Electrical - DIY Chatroom Home Improvement Forum
Old 10-03-2006, 12:38 PM   #1
We have installed pot lights in the ceiling of our addition, the entire room was gutted. Since the ceiling is going to be insulated we installed the pot lights in the approved box's, no the question I have is how to vapour barrier around the box.
mhervy is offline   Reply With Quote
Old 10-03-2006, 01:38 PM   #2
World famous jerk.
Purchase fixtures intended for that duty.
mdshunk is offline   Reply With Quote
Old 10-03-2006, 02:04 PM   #3
thats what i did, however they don't come insulated and vapour barriered...
Old 10-03-2006, 02:24 PM   #4
mhervy,
You need to get intouch with the mfg of the product and follow the reccomended installation instructions.
Recess lights generate alot of heat that needs to be disapated some how.
Installing a vapor barrier or insulation arround the box, may create a spot where heat can build up and start a fire in your house.
jwhite is offline   Reply With Quote
Old 10-03-2006, 03:29 PM   #5
jwhite, I'll see if i can get a hold of the manuf. I'm aware of the heat generated by this type of lighting, that is why pot lights installed in insulated ceilings must be installed in CSA approved boxes. However Building code states a complete vapour seal as well as insulation standards that must be met.
moisture behind vapour barrier piperboy General DIY Discussions 9 10-21-2008 12:49 PM
Double Vapour Barrier? canadaclub Building & Construction 4 01-14-2007 05:42 PM
Vapour Barrier mhervy General DIY Discussions 4 10-19-2006 01:07 PM
Is this a double vapour barrier or not? KUIPORNG Remodeling 11 09-29-2006 10:13 AM
Hot Light Outlets Materials Guru Electrical 5 07-31-2006 07:11 PM
