Vapor Barrier - Electrical - DIY Chatroom Home Improvement Forum
Old 12-12-2011, 11:26 PM   #1
vapor barrier
Is a vapor barrier needed for garage walls. I have the electrical inspector coming in and I am just wondering if it is necessary to pass for the wiring.
Chris2011 is offline   Reply With Quote
Old 12-12-2011, 11:33 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
To pass wiring? No. But I would wrap the garage anyway.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 12-13-2011, 12:13 AM   #3
Registered User
Rewards Points: 5,212
A vapor barrier installs just under the drywall in a heating climate, on the exterior in a cooling climate. You may be thinking of a water-resistive barrier (vapor permeable)-- required by Code under the siding material. Around here, the WRB is installed in order to pass electrical inspection, especially on the non-sheathed gable ends to dry-in the house walls.
Gary
