Old 06-16-2012, 08:45 AM   #1
Vanity Lights.
Okay I have a question. I have one main wire that comes from my light switch.
Is it possible to wire two lights to that one main wire coming out of the switch?
So when you go to put the black line coming from the light to the main wire coming from the switch can you just have two black wires from two lights? And with the white the same thing? Thanks so much for any guidance.
Babiez68 is offline   Reply With Quote
Old 06-16-2012, 08:49 AM   #2
Licensed Electrician
k_buz's Avatar
Vanity Lights.
The quick answer is yes, but more importantly, what are you exactly trying to do?
Location...Location...Location
Old 06-16-2012, 08:52 AM   #3
Vanity Lights.
I want to have a light on either side of my mirror in my bathroom but I only have one wire. Does that make better sense? Thank you so much.
Old 06-16-2012, 08:56 AM   #4
k_buz's Avatar
Vanity Lights.
So, you have one light currently. Where is that one light? On the side of the mirror, over the mirror, on the ceiling?
Old 06-16-2012, 09:00 AM   #5
Vanity Lights.
I took it down. . . . so I have just the wire and I was going to move the box to where ever I want. Like by the left light and then pull the wires from the right light over to it.
Old 06-16-2012, 09:03 AM   #6
k_buz's Avatar
Vanity Lights.
You must install a second box and connect the two boxes with permanent wiring that is rated to be concealed.
So, you will have two cables at the box on the left, and one cable at the box on the right.
Building HVAC vent into bath vanity nolamar Carpentry 31 08-25-2011 03:33 PM
How to remove cultured marble bathroom vanity countertop goshenplumber Building & Construction 4 03-04-2011 05:56 PM
bathroom remodel at a stand still becuase of floating vanity installation diy'er on LI Kitchen & Bath Remodeling 10 11-23-2009 02:12 PM
New lights in basement CooperChloe Electrical 11 01-11-2009 12:22 PM
Bathroom Vanity Lights... after GFCI? CuCullin Electrical 4 11-12-2007 04:16 PM
