Vanity Light Vent Pipe In Way - Electrical - DIY Chatroom Home Improvement Forum
Old 01-16-2016, 06:44 PM   #1
Rewards Points: 102
Vanity light vent pipe in way
I forgot to address this before drywall went up. Now everything is up and painted. Went to mount vanity light and I have the vent pipe dead center of the vanity.
Only about 1/2" between pipe and drywall.
Also no studs near by. I can't use one of those fan box's with expandable legs because it would hit the pipe.
I was thinking about cutting hole for a box then putting in some 1/2" plywood strips attached through drywall the same way you would repair hole in drywall. Then attach pancake box to the strips of plywood.
Sound OK? Vanity light is about 7lbs. Any other options?
cwags is offline   Reply With Quote
Old 01-16-2016, 07:01 PM   #2
griz's Avatar
Rewards Points: 570
Your pancake box idea will work.
Prime example of the 6 P's principle.....
griz is offline   Reply With Quote
Old 01-16-2016, 08:35 PM   #3
Licensed electrician
Rewards Points: 996
Use one of these.
http://www.aifittings.com/catalog/fa...le-sconce-box/
Radiant Floor Heating Vent Pipe Causing Banging Noise needhelpthx HVAC 1 11-13-2014 04:57 PM
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 12:33 PM
Distance from vent pipe to clean out? toddmanqa Plumbing 2 03-24-2012 02:41 PM
using section of pipe for both drain and vent amakarevic Plumbing 6 05-11-2011 01:20 AM
Vent Pipe Stink in house zacker Plumbing 30 12-13-2010 01:19 PM
