Vanity Light - Electrical - DIY Chatroom Home Improvement Forum
Old 06-05-2011, 10:03 PM   #1
vanity light
i took down the light in bathroom and i am going to replace it with a new light but the new light attaches to a electrical box and there is none as of rigght know, what should i do
tkenna is offline   Reply With Quote
Old 06-05-2011, 10:05 PM   #2
Licensed electrician
Rewards Points: 1,258
If the new fixture requires a box you will need to install an old work box.
Old 06-05-2011, 10:08 PM   #3
is this something i can do or will i need to hire electrician
Old 06-05-2011, 10:18 PM   #4
This is a very easy project. The hard part is getting the correct box and making sure it will fit in the wall.
Old 06-05-2011, 10:24 PM   #5
Rewards Points: 1,016
What is the wall - just drywall? Is there just a small hole with the wires sticking through - and maybe a metal bracket screwed to the wall that the old light mounted on?
You need an old work box - these have ears that can be extended once the box is set into a appropriate sized hole in the wall. You need to open a larger hole in the wall - with something like a keyhole saw or drywall saw.
If you go to a big box store, they will be a few differing types of old work boxes.
Wiring 2 light fixtures to same switch and add outlet RyanS2000 Electrical 13 10-10-2010 03:17 AM
Electrical bathroom vanity light fixture HEMMY1244 Electrical 4 09-29-2010 08:40 PM
bathroom remodel at a stand still becuase of floating vanity installation diy'er on LI Kitchen & Bath Remodeling 10 11-23-2009 02:12 PM
vanity light wiring hsw55 Electrical 5 03-28-2009 08:47 PM
Trouble mounting new vanity light calicolo Electrical 4 03-31-2008 04:07 PM
