Vanity Fixture Box And Drywall - Electrical - DIY Chatroom Home Improvement Forum
Old 12-13-2012, 02:40 PM   #1
Rewards Points: 115
Vanity fixture box and drywall
Hi there,
Quick question for you guys. I've got a vent stack going up a wall that I'm moving that's causing some wiring headache. I've got the studs exposed so I thought I was doing the best thing by putting in a new work box. Problem is there was no way to attach it where I wanted it due to the vent. So, it's recessed more than I'd like...a lot more. When I go to put the drywall on it will be covered completely. The box protrudes just to the end of the studs. So, I'll be about 1/2" recessed when drywall is on.
I wasn't a fan of the old work boxes, because I didn't think they were quite stout enough for the vanity light, which is heavier than it looks.
So, the question, how do I make up for the 1/2" recess when I go to put the light on after the drywall? If there is a better way to attach the box I can do that do...nothing is final yet.
Vanity fixture box and drywall-p1030094.jpg   Vanity fixture box and drywall-p1030095.jpg   Vanity fixture box and drywall-p1030096.jpg
Didymus21 is offline   Reply With Quote
Old 12-13-2012, 03:03 PM   #2
Licensed electrician
Rewards Points: 1,884
You could use something like an Arlington BE1R box extender to make up the difference.
Old 12-13-2012, 03:28 PM   #3
Rewards Points: 115
Looks promising. Does that affect the load bearing capacity of the original box?
Old 12-13-2012, 03:36 PM   #4
Rewards Points: 332
Could you flip the box around 180* and install the brace infront of the vent?
sgip2000 is offline   Reply With Quote
Old 12-13-2012, 03:45 PM   #5
No, but you will need longer 8-32 screws.
Old 12-13-2012, 08:17 PM   #6
Rewards Points: 115
I tried that, but then the box sticks out way too far....
Old 12-13-2012, 08:17 PM   #7
Resi EC
Rewards Points: 252
How far are you from the top plate?
Just wondering if you scabbed two or three 2X's from the top plate, then use
an Allied 9351,(or any nail-on ceiling box)and nail it on the scabbed boards
Gac66610 is offline   Reply With Quote
Old 12-13-2012, 08:20 PM   #8
Rewards Points: 115
That's a possibility. It's not a great distance, but it would be more work at this point. I suppose if I can still use the box I've already installed , I'd prefer it.
Old 12-13-2012, 08:25 PM   #9
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Add a stud and use a nail on box.
Old 12-13-2012, 08:40 PM   #10
Rewards Points: 115
Bottom piece of drywall is glued and screwed
Old 12-14-2012, 08:01 PM   #11
Rewards Points: 240
You could put in a piece of blocking above the top of the bottom drywall piece, and then put in a cripple stud.
fa_f3_20 is offline   Reply With Quote
