Is This A Valid Way To Wire A Light? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-07-2013, 10:20 AM   #1
Rewards Points: 201
Is this a valid way to wire a light?
In our basement room there is 1 light with 1 switch. This switch only operates the one light and nothing else (that I can see anyways).
I haven't seen this wiring before, doesn't seem right but the light works fine. I am trying to figure it out because I want to take out some drop ceiling and wire 2 lights as opposed to just the one.
Thanks!
NickWa is offline   Reply With Quote
Old 09-07-2013, 10:27 AM   #2
Licensed electrician
Rewards Points: 1,778
The two top cables in your diagram are power in and power out. The bottom cable is wired in a switch loop. The white takes power down to the switch. The black is the switched hot back to the fixture.
The white should be re-identified as a hot.
Old 09-07-2013, 10:36 AM   #3
Rewards Points: 2,516
that is acceptable
hammerlane is offline   Reply With Quote
Old 09-07-2013, 02:24 PM   #4
joed's Avatar
Rewards Points: 13,346
That is a switch loop. It was valid for years.
Under current code requiring a neutral at the switch that is not a valid way.
Track light wire identification AceMcCool Electrical 7 09-24-2012 01:10 PM
removing uv lighting and adding track light AlexanderGuy Electrical 2 08-12-2012 06:40 AM
confusion with track light stephenbishop Electrical 7 03-10-2012 01:37 PM
Adding ground in old home ChaosTheory Electrical 6 06-16-2010 04:02 PM
Replacement Light Fixture - Speed Wire Clip? nick4597 Electrical 4 01-03-2009 12:49 PM
