Vacuum Blows Circuit Breakers - Electrical - DIY Chatroom Home Improvement Forum
Old 12-21-2011, 09:03 AM   #1
Rewards Points: 101
This is very strange. My upright vacuum cleaner blows the circuit breaker in one of the bedrooms in my home. I've tried unplugging everything else on the circuit and turning off the lights in the room but the vacuum still blows the circuit!
This is a fairly new house and I think it's pretty well built. The vacuum is also fairly new too. Any ideas?
michaelson is offline   Reply With Quote
Old 12-21-2011, 09:07 AM   #2
the Musigician
DangerMouse's Avatar
Does the vacuum work okay in other places?
DM
Old 12-21-2011, 09:13 AM   #3
Rewards Points: 101
Yes, the vacuum works fine in all other rooms. To vacuum the problem room I just run an extension cord from the bathroom.
**Also, I've tried other high power appliances in there too. My microwave takes more power than the vacuum cleaner, but it runs fine in there.
Old 12-21-2011, 09:18 AM   #4
the Musigician
Perhaps a loose wire in the outlet or panel?
DM
Old 12-21-2011, 09:20 AM   #5
the Musigician
...also.... bedroom? Is the breaker an AFCI?
DM
Old 12-21-2011, 09:25 AM   #6
Rewards Points: 101
I've tried different outlets in the same room; they all do it. What is an AFCI?
Old 12-21-2011, 09:52 AM   #7
the Musigician
arc fault circuit interrupt - breaker. now required for many of us.
They're also problematic when it comes to high amp starters like vacuums, pumps, etc.
DM
Old 12-21-2011, 09:55 AM   #8
the Musigician
Of course it COULD still just be a loose wire in the panel or the first outlet in the room.... hard to say.
....or other reasons!
DM
Old 12-21-2011, 10:06 AM   #9
Check if it's an AFCI breaker, should be easy to identify in your panel.
If it is, try the vacuum on another AFCI circuit in your house.
It may be detecting an arc in the vacuum.
fuzzball03 is offline   Reply With Quote
Old 12-21-2011, 10:56 AM   #10
Rewards Points: 101
How do I identify a AFCI breaker? There are four with an additional push button (one for each bedroom and one for the hallway). Are these them?
Old 12-21-2011, 11:00 AM   #11
the Musigician
Little blue (most likely) test buttons? Sounds like afci alright.
Do they light up when you turn them off and back on?
DM
Old 12-21-2011, 11:00 AM   #12
If you read the actual breaker, it will state:
"AFI COMBINATION" or "ARC FAULT INTERRUPTER"
or similar
For Square D, the "white" test buttons indicate an AFCI
Old 12-21-2011, 11:04 AM   #13
the Musigician
Seimens are blue, and the writing is too tiny for an old man like me to read.
DM
Old 12-21-2011, 11:05 AM   #14
the Musigician
....and the bedrooms is where I was required to install mine, although NOW I think they're required in more than just the bedrooms....
DM
Old 12-21-2011, 11:10 AM   #15
DM
Good point - I take my unassisted(for now) eyesight for granted.
DM
Correct - depending what NEC your AHJ enforces... starting with the '08 NEC they started requiring them in more places, and now with the 2011 NEC it is just about anywhere in the house you wont find a GFCI already installed.
The Following User Says Thank You to fuzzball03 For This Useful Post:
DangerMouse (12-21-2011)
Arc fault circuit breakers bkvanbek Electrical 6 06-10-2011 11:39 AM
Why the wide price range in receptacles and switches? Evil Scotsman Electrical 11 11-22-2010 11:43 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 07:59 PM
Sub-Panel or Tandem Circuit Breakers? dgoldsmith Electrical 2 03-08-2008 12:34 PM
Circuit Breakers Unregistered Electrical 4 09-13-2004 08:49 AM
