Utility Room - Electrical - DIY Chatroom Home Improvement Forum
Old 03-28-2012, 02:43 PM   #1
Utility Room
I have a quick question...I live in Calgary, AB, Canada and in the process of developing my basement.
I know that I am to have at least one receptacle on a seperate circuit...I'm hoping that on this circuit I can have a single light as well. Is this ok as far as code? If not, my central vacuum will be wired into the room...can this be considered "one recep on a seperate circuit"?
Thanks,
Mitch
MLayden is offline   Reply With Quote
Old 04-10-2012, 11:01 AM   #2
Utility Room
In case someone ever comes searching for this answer I thought I would post what I found out from the inspector in my area...
No, you don't need a dedicated recep for a utility room. It can be a part of the circuit for the whole room. Furnace must be on it's on breaker.
Old 04-10-2012, 11:05 AM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Utility Room
I don't know the codes for Canada, so I won't comment on that part of it. But I'm pretty sure the central vac will require is own circuit as part of its specs.
Old 04-10-2012, 11:14 AM   #4
Utility Room
k buz...yes you do need the central vac on own circuit in Canada too. should have mentioned that.
Insulating a cold/well room? Lynch Building & Construction 23 07-25-2014 03:49 PM
How big should a mechanical/utility room be? reveriereptile Building & Construction 30 03-14-2012 09:11 AM
Painting room finally Imkindofbigdeal Painting 10 03-16-2011 04:22 PM
sound proofing utility room BlueBSH Drywall & Plaster 29 12-24-2009 01:44 PM
Freeze protection in utility room? akguy HVAC 1 11-20-2009 06:30 AM
