Utilitech #16616 3in Recessed Light - Electrical - DIY Chatroom Home Improvement Forum
Old 05-27-2010, 09:12 AM   #1
Utilitech #16616 3in recessed light
I have 3 in ceiling for task lighting. They overheat and shut off and on. What do I need to do?
Gale French is offline   Reply With Quote
Old 05-27-2010, 10:02 AM   #2
Check the bulbs you are using VS the rating on the can to see if you can use the bulbs
Check to see if the cans are IC rated (in contact with insulation)
or...easier
Switch to CFL bulbs to reduce the heat created
Old 05-27-2010, 10:09 AM   #3
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 688
With a 3" recessed light, I'm guessing they use those little halogen MR16 for light bulbs, right? Those things can get scorching hot. Since their connectors do not accommodate CFL bulbs, you might have to look into LED replacments.
Here's an example of a replacement bulb from HomeDepot. They'll cost you a bit, but you will never worry about heat again.
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
hyunelan2 is offline   Reply With Quote
Old 05-27-2010, 10:23 AM   #4
MR16 CFL bulb:
The Following User Says Thank You to Scuba_Dave For This Useful Post:
hyunelan2 (05-27-2010)
Old 05-27-2010, 10:27 AM   #5
hyunelan2's Avatar
Rewards Points: 688
I had no idea they were able to compact the CFL down small enough to fit into an MR16. Good to know. HD and Lowes only carry LEDs as Halogen alternatives.
Old 05-27-2010, 11:31 AM   #6
I didn't think they had them either
I stumbled across them last year when I was looking into different options
I ended up buying a bunch (40) of 12v LED MR16's & making my own setup for an LED lighting system thru the house
Recessed light suggestions? vyjeff Electrical 1 04-27-2010 01:26 AM
Bathroom remodel - recessed light above shower bigburb Remodeling 6 10-02-2009 12:03 AM
Can I use recessed light wiring for a regualr light? integrity634 Electrical 1 03-18-2009 06:29 PM
Recessed Light on Curved Ceiling? mfleming Electrical 2 10-31-2008 06:53 PM
Recessed light plan foiled? kcrossley2 Electrical 8 03-14-2007 11:08 PM
