Using Well Pump Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 05-09-2013, 08:24 AM   #1
Using well pump wire
Almost new ,10 ga 4 wire side by side with heavy plastic? yellow insulation. I have 350 ft of this in a roll and would like to use it for other projects. What say ye?.
bones1 is offline   Reply With Quote
Old 05-09-2013, 09:32 AM   #2
What exactly does the cable say on it?
Amilsmithly is offline   Reply With Quote
Old 05-09-2013, 09:40 AM   #3
I am not near the wire so I can't say. It's a shame not to be able to use it for wiring projects.
Old 05-09-2013, 09:43 AM   #4
JW
mm11's Avatar
Rewards Points: 592
Good question.
The rating of the cable will determine how it can be used.
mm11 is online now   Reply With Quote
The Following User Says Thank You to mm11 For This Useful Post:
MTN REMODEL LLC (05-09-2013)
Old 05-09-2013, 09:44 AM   #5
Make a project out of stripping the insulation off and taking it to the scrap yard for cash.
Old 05-09-2013, 07:08 PM   #6
dmxtothemax's Avatar
Rewards Points: 5,096
Originally Posted by mm11 View Post
Good question.
The color of the cable could also be an issue !
dmxtothemax is offline   Reply With Quote
Old 05-10-2013, 08:24 AM   #7
JW
mm11's Avatar
Rewards Points: 592
Why is that?
jproffer (05-10-2013)
Old 05-10-2013, 10:57 AM   #8
Special User
Rewards Points: 1,230
NM cable is typically white for 14ga, yellow for 12ga, and orange for 10ga, but I don't believe specific jacket colors are required under code.
The colors of the individual wires inside the cable definitely need to have the code-required colors, but there's plenty of 12ga NM out there that has a black or white jacket.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
The Following User Says Thank You to tylernt For This Useful Post:
clashley (05-10-2013)
Old 05-10-2013, 12:18 PM   #9
JW
mm11's Avatar
Rewards Points: 592
It's common to find older #12 NM with a white outer jacket.
There are no code required colors for ungrounded (hot) conductors, except for the high leg delta conductor, which is required to be orange. The trade practice around here is 120V colors are black, red, blue, and 277V colors are brown, orange, yellow. I have heard of purple also used as a 277V color.
Old 05-10-2013, 12:25 PM   #10
Licensed electrician
Rewards Points: 996
As it is designed for outside usage I doubt that it has a flame retardant sheath that would be required to allow its use inside.
Old 05-10-2013, 01:36 PM   #11
Oso954's Avatar
Rewards Points: 402
What does almost new mean ? If it has never been off the roll and just sitting in storage, you can probably sell it to a well pump company. If it has been down a well casing, I wouldn't use it.
For those that don't know what it is, a photo.
Oso954 is offline   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
mm11 (05-10-2013)
Old 05-10-2013, 01:43 PM   #12
Special User
Hm, that's not a cable. I see no jacket. If the conductors are individually marked with gauge, voltage, and a rating like "THWN" you could probably use it for hot conductors inside conduit, but without proper markings I think we're back to Amilsmithly's idea...
Old 05-10-2013, 03:47 PM   #13
Oso954's Avatar
Rewards Points: 402
Why do you think having a jacket is a requirement to be a cable ?
Ever hear of ribbon cable ? Or flat cable (type fc) ?
Old 05-10-2013, 03:49 PM   #14
Special User
Touché.
New thermostat - Heat Pump - Mystery "K" wire eviljuan HVAC 7 03-20-2013 05:19 PM
How to wire a 30A 250v plug and connect it to a well pump control box diyorgobroke Electrical 3 05-21-2012 05:08 PM
What size wire for above ground swimming pool pump jshep105 Electrical 12 05-28-2011 07:43 AM
Sump pump operation MikeKy55 Plumbing 16 05-11-2011 05:35 PM
Low Well Pressure, Submersible Well Pump, Help Please! tpolk Plumbing 7 11-13-2009 07:13 PM
