Using Weight Scale As A Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 09-30-2012, 07:02 PM   #1
Using Weight Scale as a switch
So basically I'm looking for a weight activated switch
i was wondering if it is possible to use a digital (or normal) scale to calculate the weight and a certain weight activate the switch.
I dont mind buying one but would prefer building one if possible.If this possible how would i go about doing it?
resources that will point me in the right direction are appreciated as well.
Edit: More Details.
I'm trying to build an automatic blender. At first I was using pump switches but what i found is that when the motor turns on the disruption of the water messes with the switch (the container is to small). So the best idea seems to be that I should make it weight activated.
So far what I've done is taking out the motor and removed all the different mode buttons. I built a mixing shaft and attached it to the motor (which has problems of its own). Changing containers is an option but I weight activated switch would give me a lot more flexibilty and allow for my container to be smaller.
In terms of price I'm not willing to pay industrial prices I really just want to build my own.
Hopefully this makes more sense.
blackbrawler is offline   Reply With Quote
Old 09-30-2012, 07:13 PM   #2
Rewards Points: 13,712
If you explain exactly what it is your really trying to do there may be something already out there that does this.
Old 09-30-2012, 07:22 PM   #3
I want my motor to activate when i pour a couple of gallons of water in it (or anything for that matter_.
I know that a float switch is an option but they are too big for the container.
I'm thinking about a float valve maybe but the best option for me is a weight activated switch.
Old 09-30-2012, 07:58 PM   #4
An old Tradesmen
Rewards Points: 7,304
Moved to Electrical forum.
Old 09-30-2012, 07:59 PM   #5
Msradell's Avatar
Rewards Points: 210
Would a photocell looking through the container work for your applications? It's certainly possible to use the scale like you're suggesting but it will be relatively expensive to set up. Another option if you have room outside of the container would be just to use a balance scale that actuated a switch when the balance shifted sides!
Msradell is online now   Reply With Quote
Old 09-30-2012, 08:13 PM   #6
I don't think a photocell would work. Why would it be expensive?
I think having a balance scale that actuated when the scale is shifted is a good idea, but what would i do about the force of the liquid when it falls in the container?
Old 09-30-2012, 08:46 PM   #7
Msradell's Avatar
Rewards Points: 210
Electronic scales in general are relatively expensive especially if they have an adjustable set point and outputs. As far as the balance scale goes it would be dependent on how accurate you want to be in how fast the water would be entering.
Old 09-30-2012, 08:55 PM   #8
what kind of motor are you pouring water into? it need more explanation as to what you are trying to do.
Old 09-30-2012, 09:03 PM   #9
Weight scales go for under $20? Do you mean an already made weight activated switch is expensive or you mean making one is expensive, or both?
I guess i dont need it to be that accurate i just need to make sure it goes off when there is a reasonable amount of liquid.
Old 09-30-2012, 09:44 PM   #10
Msradell's Avatar
Rewards Points: 210
Yes, a weight activated switch will be relatively expensive because they are intended for industrial use.
In that case in mechanical scale would probably work.
The Following User Says Thank You to Msradell For This Useful Post:
oh'mike (10-01-2012)
Old 09-30-2012, 09:52 PM   #11
then i guess i'll just use the mechanical one but, I just cant help but shake the feeling it should be able to....
wait... a switch can be activated by a custom voltage (or currency) right?
Old 09-30-2012, 10:03 PM   #12
Missouri Bound's Avatar
Perhaps if your question was more defining and your answers less cryptic we could actually help you.
Do you want it your way or the right way?
Old 09-30-2012, 10:13 PM   #13
Man i get that a lot. I dont understand how it's cryptic though.
Old 09-30-2012, 10:15 PM   #14
Brother, it's up to you to figure that out.
Old 10-01-2012, 07:58 AM   #15
joed's Avatar
Rewards Points: 12,862
Simple lever with a switch under it. Use a spring to hold the lever up. As the weight is applied the lever goes down. Use some sort of screw and washer to compress the spring as an adjustment. Think of the switch pictured with a longer arm on it and spring to adjust the weight.
Light in one lighted three-way switch not working dalepres Electrical 2 06-26-2012 06:27 AM
Digital Touch Screen Dimmer Switch Wiring Audiotekm Electrical 24 12-04-2011 09:46 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
