Using Third Conductor As Ground - Electrical - DIY Chatroom Home Improvement Forum
Old 04-17-2011, 12:41 PM   #1
Rewards Points: 91
using third conductor as ground
Is it OK to re-label the third (red) conductor in a 3C wire as ground, provided that you wrap green tape around the ends in the panel and device?
debiasio is offline   Reply With Quote
Old 04-17-2011, 12:58 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
Absolutely not.
WHY would you need to???
Old 04-17-2011, 12:58 PM   #3
Learning by Doing
Leah Frances's Avatar
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 04-17-2011, 01:04 PM   #4
Rewards Points: 91
The original wiring of my house brought two circuits up to the 2nd floor using a three conductor wire (red, blk, white, but no ground). The red feed no longer drives a circuit. So I was thinking I can now strip that wire of its red insulation, and treat it as ground in the panel. So now I essentialy have one 2C wire w/ground coming to the junction box, and any down stream devices' gnd wires would tie into the previously red wire.
Old 04-17-2011, 01:58 PM   #5
Rewards Points: 91
answered my own question...NEC 250.119 says that for 6 AWG conductors or smaller, the EGC must be bare or have green insulation.
The Following 2 Users Say Thank You to debiasio For This Useful Post:
frenchelectrican (04-17-2011), Saturday Cowboy (04-17-2011)
Old 04-17-2011, 09:49 PM   #6
" Euro " electrician
frenchelectrican's Avatar
What type of cable you have ?
BTW please do not remark red for other useage at all per NEC code anything smaller than 16mm˛ { #6 AWG } must be bare or green anything larger it can be remarked.
Merci,
Marc
Old 04-17-2011, 09:52 PM   #7
Scared Electrician
Saturday Cowboy's Avatar
DING! Ding Ding we have a winner!! Thanks for looking up the code. It is refreshing to see someone do something but ask why! Most people just want us to bless there shoddy work so they can sleep at night.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
To ground or not to ground Red Squirrel Electrical 2 10-14-2010 08:42 PM
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 08:40 AM
Electrical Ground Problem cabinetman Electrical 15 01-28-2010 04:55 PM
Live ground wire in dryer Retired sailor Electrical 10 05-04-2009 03:26 PM
Grounding VS Bonding BillyD Electrical 24 06-22-2008 12:14 PM
