Using Solar Power To Run Ac Products. - Electrical - DIY Chatroom Home Improvement Forum
Old 01-02-2010, 12:57 PM   #1
using solar power to run ac products.
Has anyone using solar power ie, small panels to rune ac electrical appliances.
In particular electric heaters etc,.
Is enough power obtained by small solar panels to batteries to run these devices.
Do you need converters.
Will it be cheaper than running devices from the mains grid in order to reduce costs.
contin is offline   Reply With Quote
Old 01-02-2010, 01:12 PM   #2
joed's Avatar
Rewards Points: 13,276
Check the wattage of the panels and the wattage of your device. You will find you need a very large panel to run even the most smallest device.
Old 01-02-2010, 01:13 PM   #3
Yes you need a convert to take the solar panel DC power & convert to AC
A 200w panel runs about $400-600 depending upon quantity ordered & supplier
So to run a 1500w heater you would need 7 panels
Then they all need to be wired
There are DC underfloor heating matts
But they are expensive too
Old 01-02-2010, 05:44 PM   #4
Idiot Emeritus
Rewards Points: 1,492
Energy derived from an off-grid solar installation will cost about 30 cents per KWHR. Smaller systems are more, larger ones are less. There are a lot of variables though.
The solar panels don't last forever, they lose about 2% of their capacity each year. Batteries need to be replaced on a regular basis as well. These two expenses are the largest.
Electric rates in Northern Nevada are about 12 cents per KWHR.
Rob
micromind is offline   Reply With Quote
Old 01-02-2010, 06:22 PM   #5
Your location's energy prices and the solar resource of that location determines whether it would be cheaper. More than likely it would be cheaper to power from the grid in the short term. Heaters use a lot of E, so you would need a few panels to supply the power needed. Electric heaters are pretty wasteful - you may consider a more efficient way to heat your living space and then power that with solar.
rescrewableE is offline   Reply With Quote
Old 01-02-2010, 06:27 PM   #6
Assuming 100% efficiency, 1 Therm of energy can be had from approx. 0.71 gal of fuel oil, 100 cubic feet of natural gas, 1.1 gal of propane, 29 kwh of elec heat, 8.4 kwh of heat pump heat (COP = 3.5), 4.2 kwh of heat pump heat (COP = 6.9).
History of HVAC Industry Brands winkydink HVAC 8 03-25-2011 07:28 AM
Turned off power. Changed outlet. No power to entire house. pauly99 Electrical 39 03-06-2009 05:09 PM
Solar installation plan DIYGST Electrical 1 02-21-2009 05:20 PM
Amp meter Results - SE Cable Bad or Power CO jamiedolan Electrical 30 01-23-2009 12:16 AM
Help! Mystery power in complex 3-way! mnyman2003 Electrical 12 12-16-2007 01:10 PM
