Old 05-25-2012, 02:50 PM   #1
Using old knockout in service panel
I am pulling new wires to upgrade and add circuits. There is a 3" knockout previously used on the back of the service panel lower portion covered by a round metal plate. I want to use this to bring new wires in. The service panel is on an outside slump block wall and the slump block is already penetrated into the inside wide enough to pass a piece of 3" conduit. I have opened up the sheetrock on the inside. I want to do what is necessary to pass inspection. I figured on using a chase nipple and nut to secure conduit to back of panel. If this is correct then what do I do to secure the conduit on the other side of the wall on the inside?
elmaur is offline   Reply With Quote
Old 05-25-2012, 02:58 PM   #2
Licensed electrician
You are either going to need a locknut outside the box in the wall or a correct connector for the conduit. The double locknut would be for a threaded conduit like rigid or IMC.
Old 05-25-2012, 06:45 PM   #3
I accomplished my objective. I don't foresee any code issues. I used a 2 1/2" x 10" nipple, 2 locknuts and 2 plastic bushings. I tightened down one locknut as far as it would go and inserted this end of the nipple into the slump block from the inside of the house into the knockout in the panel. Attached the other locknut and bushing on the panel side and second bushing on the inside of the house end of the nipple. Feels very secure as it rests on a 2x4 perpendicular to the nipple in the wall.
Section 310.15(B)(6) vs. 210.4. Don't assume, call your friendly AHJs! Daneel Electrical 3 04-11-2012 08:24 AM
Old House Rewire finnimus Electrical 15 05-13-2011 11:39 PM
200 amp breaker in a 100 amp service panel? CalMag Electrical 5 09-12-2010 09:00 PM
200 amp panel w/100 amp service PirateKatz Electrical 8 12-26-2009 04:42 PM
New service panel + Generator transfer Nhrafan Electrical 1 04-22-2008 12:05 AM
